Driverside trunk panel removal need help
Old Aug 9, 2006 | 02:53 PM
95blackintegra's Avatar
Default Driverside trunk panel removal need help
How do I remove the rear driverside panel cause I want to disconnect the antenna motor? Does it just pop off or do I need to unscrew any bolts?
Old Aug 9, 2006 | 02:58 PM
kchungb17a's Avatar
Default Re: Driverside trunk panel removal need help (95blackintegra)
HB? 4 door? There are some fasteners in there, but it's pretty straight forward.
Old Aug 9, 2006 | 03:12 PM
PrinceAli132's Avatar
Default Re: Driverside trunk panel removal need help (kchungb17a)
http://www.team-integra.net/se...D=914
Or you can use this article and it shows you how to remove the panel near the end.
http://www.team-integra.net/se...D=180
Ali
ALL MOTOR DA
Jan 7, 2011 06:41 PM
AlphaKennyWun
10
Dec 28, 2009 07:41 PM
importfan85
Aug 20, 2008 07:30 PM
doughboixx
Jun 27, 2007 08:11 PM
RedRex8
May 3, 2003 12:40 PM
