engine noise....help
Old Aug 11, 2006 | 10:36 PM
Sic_DA_Nine's Avatar
Default engine noise....help
i recently swapped in a stock LS motor.....and havent had any problems with it...
until now....
i noticed that my engine bay is extremly noisy now...and when i open up the throttle...it makes this noise....
i cant really xplain the noise...but it kinda sounds like the noise you make with your tounge back in the childhood days to imitate a machine gun...
i dunno whats up...
anyone have any ideas
Old Aug 11, 2006 | 11:21 PM
PrinceAli132's Avatar
Default Re: engine noise....help (Sic_DC_FOE)
Is it kind of like a clicking noise. Check your valve clearances. You might need a valve adjustment.
Ali
Old Aug 11, 2006 | 11:25 PM
its realy hard to explain...
its not clicking i believe...
just the noise that i tried to describe
Old Aug 11, 2006 | 11:34 PM
Default Re: (Sic_DC_FOE)
Maybe check your belts . Not really sure, im kinda having a hard time imagining the sound, try take a sound clip if you can. Sorry if i wasn't able to help.
Ali
Old Aug 12, 2006 | 11:08 AM
Default Re: (PrinceAli132)
i just came from my garage...and i know where the noise is comming from...
its whenever i let go of the clutch pedal....
when i press down on the clutch pedal, the noise goes away......
i recently had a act 6 puck and clutchmaster flywheel put in...
anyone wsup with that?
Old Aug 12, 2006 | 11:17 AM
CleanLikeJdm's Avatar
Hype-R Stalker
Sounds clutch related then, sometimes might be hitting the flywheel, or rubbing.
How long ago was "recently" ?
Old Aug 12, 2006 | 11:19 AM
Default Re: (CleanLikeJdm)
the clutch+flywheel was put in on.....i believe......mid july
Old Aug 12, 2006 | 11:24 AM
Hype-R Stalker
Was it done by a shop, or yourself?
If it was a shop, I would see if they could possibly check it.
(Unless they want a lotta money.)
Has it been fully broken in also? or Improperly broken in?
Old Aug 12, 2006 | 11:44 AM
got it dont by a shop..but its a far distant from me...
i havent really drivin on it hard...just normal driving..but when i had it on aftera week or so....i tried it out to see how itll pull...thats about it
Old Aug 13, 2006 | 09:27 PM
could this be the throw out bearing?
Old Aug 14, 2006 | 08:39 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sic_DC_FOE &raquo;</TD></TR><TR><TD CLASS="quote">could this be the throw out bearing?</TD></TR></TABLE>
no response?
Old Aug 14, 2006 | 09:13 AM
aznsins88's Avatar
yes check the throw out bearing...i had the same problem and when i fixed it the noise went away
1clean01
Honda Civic (2001 - 2005)
May 2, 2012 08:11 PM
DXH
Oct 1, 2006 11:55 AM
ToFu-DeLiVeRy
Jul 20, 2004 08:16 PM
.MilanoRex
13
Sep 15, 2003 06:20 PM
