Cluster wiring? missing stuff? Help!!!
Old Sep 21, 2006 | 10:16 AM
chrisfletcher's Avatar
Default Cluster wiring? missing stuff? Help!!!
Well, i bought a 95 gsr shell, and whoever jacked the gauges also decided they needed the cluster plugs too.... So they cut them off the harness. I bought whta i was told was a set of cluster plugs for a gsr, but the color coding is different, and its even a different amount of wires... am i missing something here???
And theese are the plugs i bought...
Also...if anyone knows what these plugs are supposed to go to, thatd be great too!
(the 2 little blue ones...they live on the passenger side, near ecu plugs)
brown plug lives near hood release
and a big freakin' hole in the dash thats all butchered...what originally is supposed to be there? theres a similar one on the other side of the steeringwheel, but that holds the "Cruise" button.
Old Sep 21, 2006 | 12:34 PM
toffytof's Avatar
don't know anything about the electronics, but the hole in the dash in the last picture is where the dash light dimmer dial goes
Old Sep 21, 2006 | 12:53 PM
Default Re: (toffytof)
thats a step in the right direction. thank you!
Old Sep 21, 2006 | 07:32 PM
Default Re: Cluster wiring? missing stuff? Help!!! (chrisfletcher)
anyone??
Old Sep 21, 2006 | 09:34 PM
Sumslapper's Avatar
Year 3030
what a mess. good luck man bump4u
Old Sep 22, 2006 | 05:10 AM
Default Re: Cluster wiring? missing stuff? Help!!! (sumslapper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sumslapper &raquo;</TD></TR><TR><TD CLASS="quote"> what a mess. good luck man bump4u</TD></TR></TABLE>
Indeed....looks like ill be buying a manual. Its not THAT bad, i just thought id see if anyone here knew where i could get a wiring diagram before i had to go buy one... Just doing my best to save this gsr from an untimely demise.
sireg6
May 19, 2007 11:33 AM
DB8-teggy
Aug 21, 2006 12:45 PM
Mike17
Jan 21, 2005 05:51 AM
allmotor.net
Mar 17, 2003 05:41 PM
