Help with header leak
Old Sep 19, 2006 | 01:22 PM
saleen288's Avatar
Default Help with header leak
i just put on a dc sports 4-1 header and it leaks at the test pipe so i went to schucks and bought 2 of these lead o ring gasket things how do these go in?
Old Sep 19, 2006 | 04:15 PM
chinaski's Avatar
Default Re: Help with header leak (saleen288)
you have to take the header out, and if its the gasket that im thinking about, then it should look like a doughnut. look at where the header meets the cat and there you will see a similar gasket, pull or pry it off of the header and put the new one on. pretty simple, and you only need one. also be on the lookout for warping if you bought a two piece ceramic header, where the manifold meets the downpipe.
ntcivic
May 24, 2010 04:39 PM
qazaq
Nov 8, 2006 06:23 AM
Wazup
Sep 7, 2005 01:08 PM
Red_Si
20
Dec 16, 2004 08:13 AM
