alt question
Old Sep 20, 2006 | 04:45 PM
gsober's Avatar
Default alt question
if you disconect the neg. side of the batt while the car is running, the car should continue correct? if it shuts off it is becuase of the alt? any hints?
Old Sep 20, 2006 | 04:52 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: alt question (gsober)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsober &raquo;</TD></TR><TR><TD CLASS="quote">if you disconect the neg. side of the batt while the car is running, the car should continue correct? if it shuts off it is becuase of the alt? any hints?</TD></TR></TABLE>
This should come with a disclaimer warning. H2 + spark = boom!
Technically it should keep running.
Old Sep 20, 2006 | 04:56 PM
gsober's Avatar
i do not want to keep going through batt.
Old Sep 20, 2006 | 04:58 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: (gsober)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsober &raquo;</TD></TR><TR><TD CLASS="quote">i do not want to keep going through batt.</TD></TR></TABLE>
You are going through batteries? Is your voltage high when running?
Old Sep 20, 2006 | 05:01 PM
gsober's Avatar
not sure. on the vafc it reads 11-13
Old Sep 20, 2006 | 05:05 PM
Dogginator's Avatar
Daisy... Daisy...
Go to a parts atore and have them check it. It should be reading higher than 11-13V. Your alternator may be dead or dying.
Old Sep 20, 2006 | 05:08 PM
gsober's Avatar
is it easy to take out? can i drive the car and feel safe that it will start?
Old Sep 20, 2006 | 09:38 PM
dc5_integra's Avatar
It should be a steady 13.4 volts to the battery at idle so if its charging at 11 volts at idle its not charging the battery enough since batteries should stay at a steady 12.6 volts or more after start. Sounds like your alternator is toast.
Old Sep 21, 2006 | 03:02 AM
gsober's Avatar
that is what i figured. car only has 65k on a 95 gsr
s2knewb
Honda S2000
28
Jul 7, 2008 12:16 PM
Fat Chick Magnet
Jun 3, 2007 05:22 PM
ekim952522000
25
Jun 1, 2006 03:32 PM
Fabman
Jul 15, 2005 10:13 AM
zseeanz
11
Nov 26, 2003 06:09 AM
