what to do when changing pistons
Old Sep 20, 2006 | 07:24 AM
DARKTEG_'s Avatar
Default what to do when changing pistons
ok, i don't know a whole lot about changing compression and piston stuff... but if i were to put b16 pistons, gsr pistons, or itr pistons in my ls motor what all do i have to do? and what kinda difference i'm i going to see? i did a search already, and couldn't find the info i was looking for
Old Sep 20, 2006 | 08:07 AM
Jay Blazed's Avatar
are u serious
have you ever built a motor b4??
this like a 7-9 on the 1-10 scale soooo
get a helms manual ....your gonna need like 500$ in just tools to do this right
anyone else with motor building exp wanna chime in ??
Old Sep 20, 2006 | 08:52 AM
VTECth1s's Avatar
Default Re: what to do when changing pistons (DARKTEG_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DARKTEG_ &raquo;</TD></TR><TR><TD CLASS="quote">ok, i don't know a whole lot about changing compression and piston stuff... but if i were to put b16 pistons, gsr pistons, or itr pistons in my ls motor what all do i have to do? and what kinda difference i'm i going to see? i did a search already, and couldn't find the info i was looking for</TD></TR></TABLE>
you can use any b-series piston setup..except for b20 since they oversized. you will need to hone the block and have the rest done and installed by a professional or a reputable shop. Don't do it yourself unless you've done it before many many times or experienced builder...
Old Sep 20, 2006 | 10:06 AM
DARKTEG_'s Avatar
Default Re: (Jay Blazed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jay Blazed &raquo;</TD></TR><TR><TD CLASS="quote">are u serious
anyone else with motor building exp wanna chime in ??</TD></TR></TABLE>
no i've never ripped apart a blockbefore...i thought that would have been obvious but the question....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egg6vtak &raquo;</TD></TR><TR><TD CLASS="quote">you can use any b-series piston setup..except for b20 since they oversized. you will need to hone the block and have the rest done and installed by a professional or a reputable shop. Don't do it yourself unless you've done it before many many times or experienced builder...</TD></TR></TABLE>
yes i'm getting a professional to do it.... i'm just wondering what all i'm gonna need, or do as well....
Old Sep 20, 2006 | 10:30 AM
Tha_liks's Avatar
Default Re: (DARKTEG_)
Each one of thos pistons have differnt compressions ratio, just choose the ones you want for the set up your going for. Beside the pistons you get your also going to have to get some new piston rings. Also if your rod bearings ar ok you can reuse them if they are not then You'll need new bearings as well.
Old Sep 20, 2006 | 10:35 AM
yee SERIOUS's Avatar
piston rings, bearings, and wrist pins possibly. of course new gaskets and seals too. i'd get a hone on the block
Shimakid12
48
Feb 21, 2010 12:02 PM
wesley_925
Mar 31, 2008 08:44 AM
c r x_s i
10
Aug 20, 2007 12:47 PM
boostdeliquent
Oct 14, 2006 09:06 AM
GusRock77
Honda S2000
16
Mar 1, 2005 12:24 PM
