dizzy rotor help
trying to take it off but cant. and in the center of the rotor theres no hole for a bolt. theres a hole right above it but i dont think a bolt goes in there. tried prying it but it feels like somethings is holding it on
did you take the screw off that holds it on? you have to turn the motor until the screw lines up at the back. Remove the screw and then you can use a screwdriver to lightly pry it off.
thats your problem.. There IS a screw holding it on.. you have to turn the rotor until you can see it through the little hole in the back. Its on the side of the rotor... Why dont you try looking at a manual.?
Lol, yeah u probly don't see the scrw cause it's on the other side, with the dizzy cap off turn the motor over a bit until u can see the screw. It's in the middle of the rotor.
