car bogging out....please help
ok so i have a 88 integra, obd-0 of course. About a week ago the fuel pump went out on it and it boggs out every time i give it gas. i know it is getting fuel to the head. checked injectors, some o rings were shot so i replaced them. still bogging. I put a b&m fpr on thinking the other one was shot (plus it looked a little rusty). changed the fuel filter with a brand new one. changed cap and rotor along with plugs and wires still doing the same damn thing. i honestly have no clue y it is doing this. no check engine light and no code on ecu. I did take it to many garages around my area all mechanics were clueless. a couple of them said maybe a clog in the exhaust. so i took off the exhaust still the same. also took out the o2 sensor. i also tried running it open throttle body, maybe not getting enough air. when i check the plugs they are a little black and not white at all so its getting fuel. Any help or input would help alot. i need HELP!!!
yeah one of my friends thought that and so did a mechanic i took it too, but i took the exhaust off from the header, and no it doesnt over heat. i'll check the cat out tommorrow and see also try the knock sensor i believe i got a couple laying around
**added** it also ides perfect after it is warmed up, right when u start it and has been sitting it runs good till its up to temp, maybe a clog in the header?
ok so i checked the cat out and it doesnt seem to be clogged so i beat all the **** out of it so now it is hollow. still running the same. also after thinking about it obd0 doesnt have a knock sensor.
What do you have the fuel pressure set at? I had a similar problem and turned out the FPR was set to high, the other thing that contributed to my problem doesn't matter on your car (referring to O2 in the cat).
coco718
13
Oct 5, 2011 02:27 PM
asiansgoweeee
Jul 14, 2004 08:26 AM
