brake light problem!
Old Sep 25, 2006 | 09:55 PM
GSRteggy00's Avatar
Default brake light problem!
hey guys. fairly new here. and was wondering if you could help. every morning when i leave for work, my brake light is on, even with the hand brake down. once i press on the brakes, it'll turn off, but as soon as i start moving at all, it'll turn back on. everytime i press the brakes it'll turn off, and yada yada. anyways i've recently changed all pads, bled and changed brake fluid. and it still does not fix the problem. can anyone help?? TIA
Old Sep 25, 2006 | 10:10 PM
JThrasher79's Avatar
Default Re: brake light problem! (GSRteggy00)
check the bulbs
Old Sep 25, 2006 | 10:16 PM
GSRteggy00's Avatar
i have checked the bulbs already too. and i forgot to mention it only happens cold start. once the car warms up then it's perfectly normal. could it be something is wrong with my float inside the master cylinder?
Old Sep 25, 2006 | 10:22 PM
Default Re: (GSRteggy00)
i dont think the float has anything to do with the lights. i could be wrong but i am clueless about your problem.
Old Sep 25, 2006 | 10:25 PM
GSRteggy00's Avatar
haha well now that i just thought about it, low fluid makes the light come on right? so if the float is messed up then that would explain why the light comes on when i gas it?? cause it thinks it's low on fluid?? lol i have no idea, just a guess on my part. if anyone knows let me konw please so i don't end up replacing stuff i don't need
Old Sep 25, 2006 | 10:26 PM
GSRteggy00's Avatar
oh and to clarify!! i mean the brake light on my dash......not the brake lights! lol sorry if that wasn't clear
Old Sep 25, 2006 | 10:27 PM
i totally thought you meant tail lights. lol
Old Sep 25, 2006 | 11:09 PM
GSRteggy00's Avatar
does anyone have any input??
Old Sep 25, 2006 | 11:58 PM
myintegranation's Avatar
when is the last time you checked the fluid that could be it. and every time i start my car at night and i turn the lights on it takes like 2 min for the taillights to come on
Old Sep 26, 2006 | 12:10 AM
Rajin's Avatar
Default Re: (myintegranation)
Sometimes when the cars cold started they stay on until roughly 15 minutes right?
Thats something to do with the wiring. My Toyota does it to.
Old Sep 26, 2006 | 02:30 AM
god.loves.ugly
Guest
Posts: n/a
Default Re: (Rajin)
it sounds like an electrical problem... but possibly the reservoir
Old Sep 26, 2006 | 09:57 PM
GSRteggy00's Avatar
i check my fluids weekly and it's never low on brake fluid. last night i unplugged the 2 wires on the brake master cap, and this morning. no light. lol it still comes on like it should when i have the e-brake up though. so the problem should be in that general area right?
Old Sep 27, 2006 | 07:34 AM
drbyers's Avatar
you have the well-documented emergency brake light problem.
the original brake fluid resevoir assembly wasn't designed very well on integras.
acura has since redesigned the internal filter and reservoir float, which cures the problem. the reason the light comes on in the mornings is because of temperature variation in the early morning.
go to your nearest acura dealer and order the resevoir filter (a small plastic cage) and the float (a tiny foam rubber item). Total cost should be about $10 and install it yourself.
it takes five minutes. I outta know. I had the same problem.
and NEVER use anything but acura OEM brake fluid to refill your brake fluid...
Old Sep 27, 2006 | 09:46 PM
GSRteggy00's Avatar
hey thanks alot drbyers!! i will go ahead and try that to see if that fixes the problem.
btman
Oct 12, 2007 06:11 AM
951dc5
Nov 18, 2004 02:42 PM
civicboisi
Mar 8, 2003 06:45 AM
joel
Dec 21, 2001 11:38 AM
