vtech malfunction
Old Sep 22, 2006 | 06:40 PM
integra32r's Avatar
Default vtech malfunction
vtech not working after ls/vtech swap when ecu that i recieved with the motor is plugged up wont go past 5000 rpm and vtech does not engage I've tried everything that i know need help running out of options! please
Old Sep 22, 2006 | 06:41 PM
ir0nmanx's Avatar
Default Re: vtech malfunction (integra32r)
its vtec not "vtech"
Old Sep 22, 2006 | 06:42 PM
integra32r's Avatar
hey man did you get your vtech to work i've got the same exact problem if so could you please tell me what the problem was
Old Sep 22, 2006 | 06:43 PM
Dogginator's Avatar
Daisy... Daisy...
Check that the VTEC solenoid and the VTEC pressure switch are both working.
Vtech is a phone.
Old Sep 22, 2006 | 06:51 PM
ir0nmanx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra32r &raquo;</TD></TR><TR><TD CLASS="quote">hey man did you get your vtech to work i've got the same exact problem if so could you please tell me what the problem was
Are you talking to me?
Old Sep 22, 2006 | 06:55 PM
integra32r's Avatar
Default Re: vtech malfunction (ir0nmanx)
vtec solenoid moving freely no pressure switch obdII do i need onei was told i dont need one if obdII
Old Sep 22, 2006 | 06:58 PM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra32r &raquo;</TD></TR><TR><TD CLASS="quote">vtec solenoid moving freely no pressure switch obdII do i need onei was told i dont need one if obdII
I think the JDM ECUs do not need the pressure switch. The USDM ones do. Perhaps there is a way to fake it. Which ECU are you running?
Old Sep 22, 2006 | 07:05 PM
integra32r's Avatar
Default Re: vtech malfunction (Dogginator)
stock p72 non chipped
Old Sep 22, 2006 | 07:08 PM
Dogginator's Avatar
Daisy... Daisy...
USDM or JDM? If it is USDM, it is looking for the pressure switch. Does the check engine light illuminate?
Old Sep 22, 2006 | 07:09 PM
OMG THE GOGGLES's Avatar
Definition:
"Vtech Malfunciton"
ie-
Old Sep 22, 2006 | 07:18 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: vtech malfunction (gasp0matikz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gasp0matikz &raquo;</TD></TR><TR><TD CLASS="quote">Definition:
"Vtech Malfunciton"
ie- </TD></TR></TABLE>
Sigh...
That phone says LG on it quite clearly, noit VTECH. If you are going to flame at least get it right instead of commencing an embarrasing self immoliation.
Old Sep 22, 2006 | 07:20 PM
integra32r's Avatar
throwing vtec malfunction light is there a ecu i can get without using pressure switch
Old Sep 22, 2006 | 07:22 PM
Dogginator's Avatar
Daisy... Daisy...
The JDM ones should not look for the pressure switch since the JDM VTEC solenoids do not have a switch. Search google for "hondahookup manuals" and download the one for your car. You should be able to jumper the ECU to thinking the pressure switch is properly tripped.
scottypippen147
Nov 16, 2010 03:35 PM
black_99SI
Texas -OK -LA (Sales)
Jul 3, 2007 07:11 PM
azoodica
14
Aug 2, 2006 09:27 PM
ls weez
Jun 5, 2006 08:59 PM
