Ignition Timing Steps (
Old Sep 26, 2006 | 10:14 AM
B18C-Hatch's Avatar
New User
Default Ignition Timing Steps (
Ok I have searched and just want to make sure i understand all the steps.
I jump the service connector
Let the engine run to temp (fan comes on)
Then Take the light and aim it down at the crank and adjust the dist. so it is 16BTC
Now when all this is happening the engine should be idling at 750 rpm
Are these the right steps?
Thanks
Old Sep 26, 2006 | 10:25 AM
RX3's Avatar
RX3
Default Re: Ignition Timing Steps ( (B18C-Hatch)
If you go here It will tell you what to do. The motors are the same.
http://www.g2ic.com/tegtips/engine/7.html
beocop
Dec 15, 2016 09:05 AM
iponnet
Mar 16, 2011 05:33 PM
sageuvagony
Aug 10, 2008 04:18 PM
90teg
Aug 26, 2003 01:45 AM
evo
Feb 21, 2002 05:11 PM
