94 RS with big problems
Old Oct 12, 2006 | 10:15 AM
tmars2's Avatar
Default 94 RS with big problems
I have a 94 Integra RS, all stock. The problem is that my 3 and 4 pistons are not firing. The plugs are sparking and the 1 and 2 are just fine. I have replaced the fuel injectors, but that didn't help. I also did a compression test and it was good. Any ideas?
Old Oct 12, 2006 | 10:28 AM
NtegraRacR05's Avatar
Default Re: 94 RS with big problems (tmars2)
Did you check to make sure fuel is getting to the 3rd and 4th injectors? Any CELs?
Old Oct 12, 2006 | 10:33 AM
tmars2's Avatar
Default Re: 94 RS with big problems (NtegraRacR05)
fuel is getting to them. Sorry, I am not the most car smart person, what are CELs?
Old Oct 12, 2006 | 10:36 AM
"CELs" are Check Engine Lights
Old Oct 12, 2006 | 10:38 AM
tmars2's Avatar
all lights are ok and there are noblown fuses.
Old Oct 12, 2006 | 10:43 AM
Well it is either not getting fuel or not getting spark, or not getting both of them at the correct time because if it is getting both of them at the correct time it will fire, so the only thing i know to tell you is to check the timing.
Old Oct 12, 2006 | 11:06 AM
tmars2's Avatar
what is the best way to check the timing?
Old Oct 12, 2006 | 11:31 AM
Sam92Teg's Avatar
Also check that the wires are going to the right cylinders.
brad813
May 17, 2014 10:10 PM
tarheelsoldier
Mar 15, 2007 08:46 AM
kipp
Jan 6, 2005 08:47 AM
TURBO
13
Jul 10, 2004 04:23 PM
civicwagonman
Nov 30, 2002 11:15 AM
