Question.......and need help ASAP!!
Old Oct 14, 2006 | 09:48 AM
SlammedBlackGSR's Avatar
Default Question.......and need help ASAP with pic's!!!!
I have a 95 integra gsr.........my abs light is on, but i put new fuses in and the light is off..........but where the abs is under the hood it sounds like its trying to suck in fluid and on the abs the fluid is low....its under the minuimum........how do i put fluid back in?
Modified by SlammedBlackGSR at 4:14 PM 10/14/2006
Old Oct 14, 2006 | 10:14 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Question.......and need help ASAP!! (SlammedBlackGSR)
You pull the grey cap on top of the reservoir. Where is your fluid going?
Old Oct 14, 2006 | 11:33 AM
Default Re: Question.......and need help ASAP!! (Dogginator)
yea when you pull that grey cap up theres like a pin hole.....how do u put the fluid in there it seems impossible...........all the fluid ran out b/c i was messin with it one day and took the screws off and lifted it up and all the fluid ran out........and what kind of fluid do i put in there dot what
Old Oct 14, 2006 | 02:11 PM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlammedBlackGSR &raquo;</TD></TR><TR><TD CLASS="quote">yea when you pull that grey cap up theres like a pin hole.....how do u put the fluid in there it seems impossible...........all the fluid ran out b/c i was messin with it one day and took the screws off and lifted it up and all the fluid ran out........and what kind of fluid do i put in there dot what</TD></TR></TABLE>
There is a plastic plug beneath the grey cap that needs to be removed before adding fluid. Just use DOT3 fluid.
Old Oct 14, 2006 | 03:10 PM
here is the pic of it, i couldnt figure out what you were talkin about with the cap.. anything else you can help me out with now that i have sent this pic?
Old Oct 14, 2006 | 03:25 PM
94_DC4's Avatar
They grey part is the cover. The piece with the pin hole is the actual cap. You remove it. Some people use a small phillips head screw driver to pry it off.
Old Oct 14, 2006 | 03:30 PM
Default Re: Question.......and need help ASAP!! (94_DC4)
thanks alot for all your help...........i appreciate it alot............
Old Oct 14, 2006 | 03:34 PM
94_DC4's Avatar
No problem. Just do as Dogginator said and use at least DOT3 brake fluid.
Old Oct 14, 2006 | 03:37 PM
Presto800's Avatar
While we're on the subject of abs, i looked at an RS yesterday, and forgive me if im retarded, but the abs system wasnt where it was in my old car.
in my 95 LS that i recently sold the abs system was on the passenger side of my engine bay.
In the rs i looked at it looked like the whole unit was taken out, but I could see something that looked like it behind the engine but I wasnt too sure..
eh?
Old Oct 14, 2006 | 03:42 PM
coronadrinker's Avatar
Default Re: (Presto800)
RS= no abs
Old Oct 14, 2006 | 03:45 PM
Presto800's Avatar
oh gotcha thanks.
Old Oct 14, 2006 | 04:25 PM
alright sorry guys for botherin you's.........i put the fluid in and started the car and the abs light went off..........u can hear the abs sucking in the fluid and working but maybe 2 minutes after the car is started you hear it turn off and the light comes back on.............what do you guys think it is..........should i change the fuses?
Old Oct 14, 2006 | 05:22 PM
Default Re: (SlammedBlackGSR)
can anyone help me!!! would i be a problem with the wheel sensor....thats what i heard from my buddy
Old Oct 14, 2006 | 06:03 PM
..........im bout to just get someone to turn the light off for me.........
Old Oct 14, 2006 | 06:13 PM
Dogginator's Avatar
Daisy... Daisy...
If the pump keeps cycling, the accumulator may be losing pressure. Pull the codes. There are instructions in the INtegra FAQ thread.
craiger28
Apr 25, 2009 08:44 AM
sitinduk
Aug 5, 2007 09:17 PM
FULL-REV
Aug 21, 2004 06:25 PM
dynamo
Nov 15, 2002 01:18 PM
94civicx
Sep 1, 2002 09:48 PM
