ecu codes???
Old Oct 14, 2006 | 04:31 PM
tecas finst dc4's Avatar
Default ecu codes???
my 95 ls is thrown me a code and i looked it up.. it says its a electric load detecter.?
wat is that exactly? i have msd ignition msd coil an dist. i think it mite be the coil an my other friend told me it could be the alternator... any ideas? the check engine light stays on for two long pauses. help please
Old Oct 14, 2006 | 06:07 PM
vinai's Avatar
Default Re: ecu codes??? (tecas finst dc4)
What do you need msd system for thats probly your problem. Pretty much meaing that you msd unity is drawing to much current so your car thinks it should rais the idle to compensate...(I think htat is right).unless your running boost or have some high compression pistons that is a just a waist of money. MSD systems can cause a lot of problems on pretty much stock setups. I suggest you go back to oem if you still have your stuff.
Halfbreed Soldier
Jan 11, 2007 10:43 PM
b00st-l0gic
Nov 13, 2006 04:39 AM
Devo94ac
Sep 16, 2005 08:55 AM
K-Spec
Jan 8, 2005 03:48 PM
