Starting issues
Old Oct 12, 2006 | 01:08 PM
dc4pos's Avatar
Default Starting issues
Lately when I go to start my car, I turn the key but it wont start, it doesnt click, or anything? Then I try a few more times, and maybe 3 or 4 or 5 times later it will start. This doesnt happen everytime but randomly, and its annoying. I am thinking its either the switch under the clutch pedal or the starter. If anyones has had this problem before please help me out, or if you all have any suggestions. Thanks.
P.S. It's not a battery issue becuse the stereo and the headlights turn on and stay nice and bright etc.
Old Oct 12, 2006 | 01:32 PM
Formula's Avatar
Default Re: Starting issues (dc4pos)
Your problem sounds like it could be the main fuel relay.
Also did you make sure your battery cables are tight on the terminals?
Old Oct 12, 2006 | 01:40 PM
dc4pos's Avatar
Default Re: Starting issues (Formula94)
Where is the main fuel relay? I dont have an fsm. Also yes the battery terminals are tight and shiny. I just replaced this dist. cap, rotor, wires, and plugs as well. But Im pretty sure the problem occured bofore that, and it runs fine.
Old Oct 12, 2006 | 01:53 PM
Formula's Avatar
The main fuel relay should be under the driver's side dash.
Find the fuse box and look toward the left side of it. You should see a rectangle box about 2"X 2 1/2". It will be a bolt holding it to a bracket.
You can test it with a multimeter. I personally recommend replacing it if your car is more than 10 years old because thats usually the when they start going bad.
Old Oct 12, 2006 | 02:06 PM
dc4pos's Avatar
ok ill replace that and see what happens
Old Oct 12, 2006 | 02:11 PM
Formula's Avatar
Good luck
Post on this thread after you replace it to let me know if it worked.
Old Oct 12, 2006 | 03:06 PM
da_33's Avatar
i was having the exact same problem it kinda just happens randomly. the car will be good for a month or more then all of sudden it will happen then maybe be good for a week or till the next day. do it again then its good for months again... its really strange
i already replaced the MFR to and it still does it once in awhile after that
Old Oct 12, 2006 | 03:29 PM
ugotdubbz's Avatar
Default Re: Starting issues (da_33)
I am having the same problem. I think the problem is the neutral/interlock switch. I have noticed that if I pump the clutch a couple times as I turn the ignition switch it will start. So I just, in the past couple hours, bypassed the switch with a paper clip. I will try that for a couple weeks to see if the problem goes away. If I have no problems for a while I will order a new switch.
Old Oct 12, 2006 | 03:44 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
I used to have this problem also. My old Camry also had that problem, and my dad showed me this trick where if it happens, tap the starter lightly with a hammer, and it would always start right up.
Now the starter isn't as easy to get to on an Integra as it was on my Camry, but the problem is the contacts inside the starter are worn out. You can actually rebuild the starter using a rebuild kit that you buy at a Toyota dealer (Honda doesn't sell the rebuild parts separately), and it only costs about $20. I rebuilt my starter over a year ago and it's been trouble free ever since.
I will see if I can find the thread on it, I'm pretty sure somebody made a how-to, because that's what I followed to fix mine heh.
*edit* here we go, this was the thread I made when I was having problems, and then Bret came in with the pics: https://honda-tech.com/zerothread?id=1318816
Old Oct 12, 2006 | 04:56 PM
autopro01's Avatar
hey have u got the prob. fixed ?
Old Oct 12, 2006 | 05:45 PM
str8JDMteggy's Avatar
The fuel relay? Fuel has nothing to do with the engine turning over? If the starter isnt turning the engine over your problem can be anywhere from the ignition to the starter.
Old Oct 13, 2006 | 02:26 PM
da_33's Avatar
Default Re: (str8JDMteggy)
so how come if the contacts are worn out that if u let the car sit for awhile it just always seems to start?
Modified by da_33 at 12:40 PM 10/14/2006
Old Oct 13, 2006 | 08:29 PM
Community Builder
Default Re: (da_33)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by da_33 &raquo;</TD></TR><TR><TD CLASS="quote">so how come in the contacts are worn out that if u let the car sit for awhile it just always seems to start?</TD></TR></TABLE>
Who knows, mine would do it intermittently, not all the time. But replacing the contacts fixed it right up.
FlewByU352
Sep 22, 2011 12:15 PM
dirtyharryhatch
11
Aug 1, 2008 07:46 PM
reno96teg
Apr 23, 2008 01:52 PM
junkyardRx
15
Apr 26, 2004 03:04 AM
Jolf
Aug 14, 2003 03:44 AM
