b18b
Old Oct 11, 2006 | 10:01 PM
95_red_dc's Avatar
Default b18b
I have a b18b swap in my 91 crx si obd1 conbversion and i can not get ti to idle higher than 400-500 rpms I turn the idle screw up and it does not do any thing
Old Oct 12, 2006 | 05:35 PM
95_red_dc's Avatar
Default Re: b18b (ls_swaped_crx)
bump
Old Oct 12, 2006 | 05:40 PM
DC2 Mang's Avatar
adjust the small screw on the TB that is underneath the plate that the throttle cable connects to
Old Oct 12, 2006 | 05:41 PM
str8JDMteggy's Avatar
Any vaccum lines off?
Old Oct 12, 2006 | 05:44 PM
DC2 Mang's Avatar
Default Re: (str8JDMteggy)
a vacuum leak generally causes the car to idle high
Old Oct 12, 2006 | 05:56 PM
Maybe in some cases if does but in some it doesnt. I have a line off and my car didnt want to idle.
Old Oct 12, 2006 | 09:06 PM
95_red_dc's Avatar
I tryed to turn the screw but I can not NOT get it to go any higher than 4-500 rpms , I have my charcol canister removed and capped off
Old Oct 13, 2006 | 12:03 AM
DC2 Mang's Avatar
are you running anything aftermarket? (cams, valvetrain, ecu chip)
also check your valve clearances and make sure all your vacuum is hooked up correctly
Old Oct 14, 2006 | 10:05 AM
jdmgsr94's Avatar
I work at an acura dealership and the idle adjustment screw does nothing , they want you to think it does but it has a sensor or a valve that u have to replace . Not possitive but def something to look into ........New to HT have a DC2 built pics up asap throughout the build
Old Oct 14, 2006 | 02:33 PM
95_red_dc's Avatar
Default Re: b18b (jdmgsr94)
were would this sensor be located at?
Old Oct 15, 2006 | 10:00 PM
95_red_dc's Avatar
I was able to get it to idle a little higher by moving the distributor towards the bumper a little which it was in the center is it bad to do that?
Old Oct 16, 2006 | 02:05 PM
Sam92Teg's Avatar
Yes, you just blindly adjusted your ignition timing, so who knows where it is set at now. You can make it run like a charm at idle that way, but now who knows what your timing will be at when you are higher in the rpm range. Use a timing gun.
Have you checked to see if you skipped a tooth on your timing belt?
Old Oct 16, 2006 | 04:00 PM
95_red_dc's Avatar
Default Re: b18b (Sam92Teg)
NO I have not cheacked it with a timeing gun, I need to but what other way can I fix the idle the motor just has normal bolt ons?
NayborhoodJohnny
Feb 8, 2011 07:44 PM
soodominican
Jan 16, 2009 09:32 AM
b_serious
Nov 16, 2005 09:05 AM
dsmarefaster
May 15, 2005 03:55 PM
Audipwr1
Jul 6, 2003 10:27 AM
