Need help removing head
Old Feb 6, 2007 | 08:30 AM
invisible's Avatar
Default Need help removing head
yeah so i need to remove the IM, then the adjusting screws?, where are the camshaft holder bolts (#26)?
Old Feb 6, 2007 | 12:01 PM
lVlemphizStylez's Avatar
Default Re: Need help removing head (.hue)
you can leave the IM on to remove the head....makes things easier
Old Feb 6, 2007 | 12:41 PM
wernhersey's Avatar
Default Re: Need help removing head (lVlemphizStylez)
Definitly leave the Intake man. on until you get the head off. Taking the I.M. off before just sucks royal ***.
Old Feb 6, 2007 | 12:53 PM
califasrsx's Avatar
Default Re: Need help removing head (wernhersey)
true remove head then im
Old Feb 7, 2007 | 06:34 AM
j_bizach's Avatar
Default Re: Need help removing head (califasrsx)
im on head pain in the *** to take im off
Old Feb 7, 2007 | 07:24 AM
1lowsol2's Avatar
Sine we are on this topic what about the Timing belt and not getting the car out of time?
Old Feb 7, 2007 | 11:29 AM
berb_15's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">
yeah so i need to remove the IM, then the adjusting screws?, where are the camshaft holder bolts (#26)?</TD></TR></TABLE>
These are simply the bolts that are bridge looking things that are holding the cams in(they have either an "E" or an "I" on them and a number, for exhaust/intake then the number for the order they are in. Once they are removed you can take the cam holders off and the cams will come right out, goodluck
Old Feb 7, 2007 | 12:18 PM
SuzukaBlueAP2's Avatar
Default Re: (1lowsol2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1lowsol2 &raquo;</TD></TR><TR><TD CLASS="quote">Sine we are on this topic what about the Timing belt and not getting the car out of time?</TD></TR></TABLE>
What about it? There are markings on the crank pulley and markings on the cam gears. If they are lined up in their proper place then you should have no trouble.
The easiest thing to do is set the engine to TDC. Make sure the distributor rotor is also at the no. 1 cylinder and you'll be fine.
ej1252
Oct 28, 2007 03:29 PM
usmarinedelta
Dec 4, 2006 06:25 PM
LSEGHATCH
Nov 15, 2006 12:13 PM
Strikerrr
Aug 28, 2005 11:07 AM
veilsides2000
Jul 4, 2005 03:08 PM
