need some help
Old Feb 4, 2007 | 12:47 PM
jerdizzle14's Avatar
Default need some help
hey guys im having problem with my 94 integra ls...recently i had just dropped a new ls motor in. the motor was obd2 but i used my original obd1 harness. swap went easy started the motor car running fine. had a check engine light pulled code and fixed that problem. the other day i go to start it up and it will crank but not start...my check engine light will not light up at all i have fuel pressure but no spark. i replaced coil and ignitor but still nothing i tried another ecu and still no mil. fuses were all good the ecu fuse was not blown. im just looking for some suggestions on where to start im thinking there is a short but im lost right now.. any suggestions would be a huge help thanks guys...
Old Feb 4, 2007 | 01:07 PM
BlueIntegraBoy's Avatar
Default Re: need some help (jerdizzle14)
Did you swap over the distributor ?
toytroy
Sep 27, 2012 10:06 AM
ryanevansoh
Aug 27, 2010 10:52 PM
BenB
Apr 5, 2005 09:06 AM
WrongWD
16
Oct 15, 2004 12:35 AM
ThatRicerDaniel
Aug 12, 2004 12:02 AM
