NEED SOME ADVICE
Old Feb 5, 2007 | 06:01 PM
stunnerone23's Avatar
Default NEED SOME ADVICE
ok guys im running a b18b block, with pr3 pistons boerd to 82mm, with a molly coating. a b18c head with stock valves and a 3 angle valve job. going into a del sol. what can i use from the sohc, can i use the same vtec (selanoid SP ) what tranny should i use. and what type of turbo set up can i run with out running into problems, now when i do my turbo set up can i get a bigger head gasget then 51 thousands. sorry for the crappy wording just thinking to much. but any advice would be. my compression is going to be about 12-1 and what kind of wiring am i going to look at doing this swap.
GRyderXx
Jul 22, 2011 09:52 PM
boostedb20ek
Sep 9, 2010 03:39 AM
spoonEGcivichatch
Sep 28, 2005 01:17 AM
fuguman
Sep 14, 2002 01:54 PM
blkDOHCsol
Apr 18, 2002 11:05 AM
