coolant question
Old Feb 4, 2007 | 02:59 PM
TOO MUCH TORQUE's Avatar
Default coolant question
i opened the radiator cap like a minute after i turned off the car and some green coolant shot out. is that okay?
Old Feb 4, 2007 | 03:03 PM
HomeDepotMade's Avatar
Default Re: coolant question (TOO MUCH TORQUE)
u should of waited for the car to cool down more. the coolant might have been still boiling so coolant would of came out.
Old Feb 4, 2007 | 03:08 PM
it was only on for a few minutes. the cap was cold still. but is it ok?
Old Feb 4, 2007 | 03:23 PM
Brick Top's Avatar
Default Re: (TOO MUCH TORQUE)
ya, thats normal. it's from pressure in your cooling system.
Old Feb 4, 2007 | 04:38 PM
sorry for my ignorance but what is the purpose of the radiator cap?
Old Feb 4, 2007 | 05:40 PM
Brick Top's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TOO MUCH TORQUE &raquo;</TD></TR><TR><TD CLASS="quote">sorry for my ignorance but what is the purpose of the radiator cap?</TD></TR></TABLE>
a place to fill the coolant at. and hold it in to maintain pressure.
Old Feb 4, 2007 | 06:08 PM
but the hole is so small and there is fluid that fills nearly to the top tho??
i thought there was a white tube you can poor it in?
Old Feb 4, 2007 | 06:13 PM
Brick Top's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TOO MUCH TORQUE &raquo;</TD></TR><TR><TD CLASS="quote">but the hole is so small and there is fluid that fills nearly to the top tho??
i thought there was a white tube you can poor it in?</TD></TR></TABLE>
thats the way it is. and there is a white tube. its called the overflow tank. you use that to check the fluid level. instead of popping open the radiator cap when its hot and bathing in burning coolant. but if you want to fill the radiator, thats when you pour it through the cap.
Old Feb 4, 2007 | 06:26 PM
Default Re: (brick top)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brick top &raquo;</TD></TR><TR><TD CLASS="quote">
thats the way it is. and there is a white tube. its called the overflow tank. you use that to check the fluid level. instead of popping open the radiator cap when its hot and bathing in burning coolant. but if you want to fill the radiator, thats when you pour it through the cap.</TD></TR></TABLE>
but how can you poor coolant in that cap if its already filled?
Old Feb 4, 2007 | 06:47 PM
be18see1's Avatar
its scary that youre allowed to open your hood. the cap is wat allows you to fill the radiator, the hose is for overflow, i think from wat youre saying.
Old Feb 4, 2007 | 07:50 PM
Brick Top's Avatar
but how can you poor coolant in that cap if its already filled?</TD></TR></TABLE>
if its already filled, then you don't need to pour coolant in it.
make sure that cap and your overflow tank( the white thing) are full and your ok.
YeuEmMaiMai
Oct 1, 2008 07:05 AM
aziaticvang
28
Jan 17, 2008 02:26 PM
bokals
Mar 8, 2007 07:04 PM
gsrcxhatch
May 11, 2006 07:37 PM
IntegraTionR
Sep 18, 2005 08:22 PM
