Help! Headlight out!
Old Feb 5, 2007 | 01:21 PM
TheCrookedH's Avatar
Default Help! Headlight out!
Alright, I've replace the bulb but I'm still not getting light.
JDM non-HIDS if that makes a difference.
Old Feb 5, 2007 | 01:31 PM
SlammedDC2teg's Avatar
Default Re: Help! Headlight out! (TheCrookedH)
check your wiring then check the fuse.
Old Feb 5, 2007 | 01:32 PM
Default Re: Help! Headlight out! (SlammedDC2teg)
It's only the right headlight that's out too if that makes a difference.
Old Feb 5, 2007 | 02:02 PM
GoldCoin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheCrookedH &raquo;</TD></TR><TR><TD CLASS="quote">It's only the right headlight that's out too if that makes a difference.</TD></TR></TABLE>
i say its the wiring . must be having a short somewhere
Old Feb 6, 2007 | 09:51 AM
black_cap's Avatar
Default Re: Help! Headlight out! (DC TWOin IT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC TWOin IT &raquo;</TD></TR><TR><TD CLASS="quote">
i say its the wiring . must be having a short somewhere</TD></TR></TABLE>
or a wire came loose.
Compare the left side to the right side and see if there is any difference between the two. If so, make the right side like the left. If thats not the case check your fuses.
There is a good write up on wiring the jdm front, lemme see if i can find it real quick.
found it. Good write up to https://honda-tech.com/zerothread?id=1638414
Thefbomb13
Honda Civic (2001 - 2005)
May 25, 2008 07:19 PM
nikech1
Nov 4, 2007 11:07 PM
DA9_DAD
Aug 12, 2007 09:57 PM
quick
Sep 25, 2003 09:57 PM
Nishant
Sep 10, 2003 10:11 PM
