Clutch Problem.
Old Feb 2, 2007 | 01:28 PM
Seth94GSR's Avatar
Default Clutch Problem.
I have a 94 gsr, I can start my car, but can't put it in gear. I believe it may be the clutch Slave Cylinder, but I'm not quite sure, would be nice since its cheap to fix. Anybody have any other suggestions please reply quick, Sun is starting to go down.
Old Feb 2, 2007 | 01:40 PM
GsrIntegra789's Avatar
Default Re: Clutch Problem. (Seth94GSR)
it depends. but most likely its ur throw out barring. or. it could be even more simple. something like ur clutch cylinder or the clutch might just need to be bled.
do u feel pressure when u press the clutch?
Old Feb 2, 2007 | 02:10 PM
Seth94GSR's Avatar
Default Re: Clutch Problem. (GsrIntegra789)
No, just falls straight in. I just went and purchased a CMC and CSC to replace now then later. Going to replace them, and then bleed the clutch, because I believe the CMC was leaking, because there was fluid on the rod bolt, behind the clutch pedal.
Old Feb 2, 2007 | 05:52 PM
kazman's Avatar
that just happened to my car. the pedal stayed on the floor right? mine was the slave cylinder i just topped off the master cylinder and bled it. it works fine now for a quick fix but i need to go back and replace the slave cylinder. good luck
Old Feb 3, 2007 | 01:48 AM
94LS4teg's Avatar
Check first the slave cylinder. Mine have the first problem, it is really cheap. In autozone you can get the slave cyl by 20 bucks.
TypeR324
Honda S2000
Sep 29, 2009 10:05 AM
beanwagon
Dec 12, 2008 02:55 PM
s1ngle
13
Sep 21, 2005 12:01 PM
Greenery18
Jul 8, 2005 04:22 PM
DriveSideWays
Aug 27, 2004 05:06 PM
