VAFC2 VTEC POINT?
Old Feb 4, 2007 | 08:00 PM
cslegacy's Avatar
Default VAFC2 VTEC POINT?
I have had one of these in my car for a while now and i have not touched it vtec came in really well at 6 i tryed it at 5200 and vtec did come in so hard it was kind of slow
Whats the best point for hi and low cam?
i tryed
low - 4700
High- 5200
Old Feb 4, 2007 | 08:51 PM
lVlemphizStylez's Avatar
Default Re: VAFC2 VTEC POINT? (cslegacy)
You'd need to list your setup so others can help you
Old Feb 4, 2007 | 10:12 PM
davidluko's Avatar
It's not about how hard it 'kicks' or whatever. The right way to set it is to set it to like 7000 rpm and redline the car and then set it to like 2000 rpm and redline it, and then set it at where the two power curves intersect.
Old Feb 4, 2007 | 10:16 PM
cslegacy's Avatar
i just put it on 5200 low and 5900 high it goes so much better
My car is a Honda Civic EF
b16a head
b18c block
TypeR pistons
ITR cams
TRR 4-1 extractors
Old Feb 4, 2007 | 10:18 PM
GoldCoin's Avatar
Default Re: (cslegacy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cslegacy &raquo;</TD></TR><TR><TD CLASS="quote">i just put it on 5200 low and 5900 high it goes so much better
b16a head
b18c block
TypeR pistons
ITR cams
TRR 4-1 extractors
whats your times for that. that should be one hell of a car
Old Feb 4, 2007 | 11:42 PM
Fat Chick Magnet's Avatar
5800 ?
Old Feb 5, 2007 | 12:28 AM
cslegacy's Avatar
I dont no aye bro i just got it 2 days ago its so fast&lt;3 it also has some another mods like real good clutch and flywheel
Old Feb 5, 2007 | 12:51 AM
GoldCoin's Avatar
CLEAN
Old Feb 5, 2007 | 06:13 AM
Default Re: (DC TWOin IT)
with those cams my car liked a 5500 crossover...The only REAL way to know is to throw it on a dyno and play with it...But you can try this method
1. set engagement at 7000
2. Notice where the power falls off
3. Set engagement 500 rpm before that
Old Feb 5, 2007 | 08:03 AM
Daammnn's Avatar
is it not tuned??? ur only spose to set the high and low 300 apart. mines a 4700 to 5000
Old Feb 5, 2007 | 08:37 AM
Default Re: (Daammnn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Daammnn &raquo;</TD></TR><TR><TD CLASS="quote">is it not tuned??? ur only spose to set the high and low 300 apart. mines a 4700 to 5000</TD></TR></TABLE>
wtf are you talking about...the low cam profile is before VTEC and the high cam profile is upon VTEC engagement...you don't "engage" the low profiles, it's what the car runs on off VTEC
Old Feb 5, 2007 | 08:47 AM
Daammnn's Avatar
what?you still have to adjust it..and i know low is off and high is on.
Old Feb 5, 2007 | 08:49 AM
you don't adjust the low cam engagement...because there is none...Something tells me you're referring to the secondaries..
Old Feb 5, 2007 | 08:56 AM
Daammnn's Avatar
no man when u adjust your vtec settings on the controller there is a high and a low vtec setting.
Old Feb 5, 2007 | 09:07 AM
Daammnn's Avatar
there is a changeover point form Hi to Lo cam when the rpms decrease and increase.
Old Feb 5, 2007 | 11:20 AM
are you talking about when VTEC disengages...it is PHYSICALLY IMPOSSIBLE TO ENGAGE THE LOW CAM BECAUSE FROM THE MOMENT YOU TURN THAT KEY ITS RUNNING ON THE LOW CAM...Do you understand this?? More importantly, have you seen a set of cams?? If you have you will understand what youre saying (at least the way your wording it) is completely wrong and not feasible
Old Feb 5, 2007 | 12:06 PM
davidluko's Avatar
Default Re: (lVlemphizStylez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lVlemphizStylez &raquo;</TD></TR><TR><TD CLASS="quote">are you talking about when VTEC disengages...it is PHYSICALLY IMPOSSIBLE TO ENGAGE THE LOW CAM BECAUSE FROM THE MOMENT YOU TURN THAT KEY ITS RUNNING ON THE LOW CAM...Do you understand this?? More importantly, have you seen a set of cams?? If you have you will understand what youre saying (at least the way your wording it) is completely wrong and not feasible</TD></TR></TABLE>
No actually it is possible to engage the lower cam profile, by disengaging the higher cam profile. When vtec is engaged, the higher lobe is pushing on the rocker arms and the lower lobes do not touch the rocker arms, making them 'disengaged'. You set the low rpm point for when you want vtec to disengage as RPMs drop out of vtec... and this is coming from someone who's never owned a vtec car.
Old Feb 5, 2007 | 12:47 PM
Default Re: (Hatch_R)
lmao wouldnt that just be then when VTEC disengages???...You arent engaging the lower cam..It's what the car runs on out of VTEC...A vtec disengagement RPM plays what exactly in making power???
Old Feb 5, 2007 | 12:58 PM
davidluko's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lVlemphizStylez &raquo;</TD></TR><TR><TD CLASS="quote">lmao wouldnt that just be then when VTEC disengages???...You arent engaging the lower cam..It's what the car runs on out of VTEC...A vtec disengagement RPM plays what exactly in making power???</TD></TR></TABLE>
It doesn't necessarily have to make power to have the ability to engage, plus it does make power... it helps with low-end power vs. vtec for high-end power. If it didn't, then Honda's engines would just run on the higher vtec lobes all the time and it wouldn't have been anything special.
Old Feb 5, 2007 | 01:04 PM
= / you dont know what youre talking about...but ok...Where you set your vtec "disengagement" rpm has absolutely no bearing on the dyno readout...or the 1/4 mile slip....It's where it engages that dictates the power delivery...
And last I checked....this thread was about the optimal place for it to be in order to make the most power...
Old Feb 5, 2007 | 04:30 PM
Daammnn's Avatar
dude look on the apexi website in the tech part my controller was tuned by a honda challenge professional and a apexi/toda/ems tuner.im pretty sure they know what their talking about...
Old Feb 5, 2007 | 05:18 PM
davidluko's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lVlemphizStylez &raquo;</TD></TR><TR><TD CLASS="quote">= / you dont know what youre talking about...but ok...Where you set your vtec "disengagement" rpm has absolutely no bearing on the dyno readout...or the 1/4 mile slip....It's where it engages that dictates the power delivery...
And last I checked....this thread was about the optimal place for it to be in order to make the most power...</TD></TR></TABLE>
Well yea it won't show on a dyno obviously but driving around in real life, not on a paper, it does. I think you're the one that doesn't know what you're talking about. I know what the OP is asking and I answered his question in the 2nd or 3rd post. I'm just trying to show you that you're wrong.
todahead
10
Aug 13, 2012 04:01 AM
Novtecdohc
Oct 3, 2006 07:38 PM
Contender25
Sep 6, 2006 02:56 AM
gutted
30
Jan 27, 2004 08:17 AM
goforbroke
Jun 13, 2003 10:33 AM
