compression ?
Old Feb 4, 2007 | 10:45 PM
1997 gsr's Avatar
Default compression ?
what should my compression be in each cylinder. estimate
Old Feb 4, 2007 | 10:55 PM
TOO MUCH TORQUE's Avatar
Old Feb 4, 2007 | 11:17 PM
GoldCoin's Avatar
Default Re: (TOO MUCH TORQUE)
what kind of engine??hmm i say 190 . but i wouldnt know cuz i dunno what kind of engine and yr you have.
Old Feb 4, 2007 | 11:26 PM
Fat Chick Magnet's Avatar
what about a 1997 gsr w/ 115k miles? anyone suggest what compression should be around?
Old Feb 4, 2007 | 11:35 PM
integrainside's Avatar
Default Re: (dc2rtek)
1994-2000 B18C1 & B18C5
Standard- 270 psi
Minimum- 135 psi
Max Variable Between Cyl.- 28 psi
According to Haynes Repair Manual
Old Feb 5, 2007 | 08:26 PM
1997 gsr's Avatar
well im not sure about 270 but i think im around 175- 177
Old Feb 5, 2007 | 08:29 PM
lVlemphizStylez's Avatar
Default Re: (1997 gsr)
on average a healthy b18c will be anywhere from 230-250..below 200 and you have issues
Old Jun 21, 2007 | 01:51 PM
dc2long's Avatar
Default Re: (lVlemphizStylez)
would 210 be considered healthy? just got mine done today and it was 205-210.
first i did it with the other 3 plugs in and it came out 120psi (scared me). figured out that i had to take out all the plugs and retested and got 205-210 on all cylinders.
Old Jun 21, 2007 | 01:56 PM
dc2long's Avatar
Default Re: (dc2long)
are you suppose to step on the gas while doing it? i only held the clutch in and cranked it like 5 times.
Old Jun 21, 2007 | 02:17 PM
401tuner's Avatar
i held the gas all the way down and cranked 7 times
Old Jun 22, 2007 | 11:59 AM
OC Geezer's Avatar
Yes, gas down all the way.
And I believe 250 is pretty healthy.
cheeblez
Aug 15, 2012 01:09 PM
fsp31
Jan 7, 2005 02:08 PM
JsNA99si
Jun 16, 2004 02:51 PM
nugget8000
Aug 13, 2001 09:51 AM
