Sensor in tranny....?
Old Feb 2, 2007 | 08:21 PM
Gsr94black's Avatar
Default Sensor in tranny....?
I have a '90 LS Auto teg and lately it has been havin some issues. I will put it in park after driving and i won't be able to get the key out and then the other day i couldn't get it out of park. So i sat there the other day and i noticed that the park light on the dash doesn't light up right away so once it does the key comes right out or i am able to get out of park. What sensor would be causing this b/c not only is it annoying but it is also embarassing when it happens at gas stations and things of that sort. Please help....also does anyone know where to find a free manual for this vehicle?
Old Feb 3, 2007 | 09:59 PM
Gsr94black's Avatar
Default Re: Sensor in tranny....? (Gsr94black)
WTF!!! 22 views and no responses....someone on here has to know something about this.
Old Feb 3, 2007 | 10:19 PM
Honda_ThuGZ's Avatar
mine does the same thing just move the steering wheel around and pull out the key and if that dont work move the steering wheel around and push down the brake
Old Feb 3, 2007 | 10:20 PM
Default Re: Sensor in tranny....? (Honda_ThuGZ)
o **** ma bad this is hella old lol
Old Feb 3, 2007 | 10:28 PM
Gsr94black's Avatar
what is hella old?
Old Feb 3, 2007 | 11:11 PM
Noemotion_91DA's Avatar
If the key gets stuck go down the gears and then try to put it back in park, or try pushing the shifter until it clicks to make sure the thing is in park. Have you made sure that the tranny has plenty of fluid. As far as the brake light you might want to check the rear brakes to make sure that there good.
Old Feb 4, 2007 | 03:18 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gsr94black &raquo;</TD></TR><TR><TD CLASS="quote">what is hella old?</TD></TR></TABLE>ma bas lol im hella trippin
Old Mar 25, 2007 | 11:29 AM
daver's Avatar
its not uncommon, my '92 does it, but only in the cold. i don't know the fix, and i looked into this a while back. changing the ignition cylinder wasn't the fix.
I just leave the engine running, in park, til the P lights up, then pull the key out. the colder it is, the longer i wait. If its really cold, and it takes longer than a minute, i leave the key there.
d
Old Feb 25, 2010 | 04:12 AM
REAPER101's Avatar
same here
Old Feb 25, 2010 | 04:33 AM
SkyliteCustomz's Avatar
good job bringing up an old *** thread.
Old Feb 25, 2010 | 04:35 AM
REAPER101's Avatar
yup
Roman00
Apr 12, 2018 08:43 PM
Rod06
Jun 14, 2017 07:20 AM
mish__
Honda S2000
Oct 24, 2015 06:03 PM
heyimrchills
Sep 11, 2009 01:02 PM
Hatch'd
Sep 20, 2005 09:05 PM
