Need help on an AC compressor
Old Feb 3, 2007 | 01:40 PM
djdc2's Avatar
Default Need help on an AC compressor
I have a 94 Integra RS, running on a b18b. After getting into a small accident that kinked one of my pipes...I finally repaired anything that was leaking.
Now my problem is that when I put everything together, I noticed that the AC compressor has this skinny prong looking thing
...I googled an image...though it's small, I hope you can see it
Those 2 wires you see near the clutch. 1 of them is attached to the block of the compressor itself...I was thinking this is the ground wire. But the other one that's a little bit longer, I don't know what to do with this or where it "was" connected to.
ANyone please help me. I'd greatly appreciate it. If you have pics of where this wire thing conencts to that's be awesome.
Thanks.
Old Feb 7, 2007 | 01:17 PM
djdc2's Avatar
Default Re: Need help on an AC compressor (djdc2)
Just an update...if anyone can help me.
I found the plug that the wire needs to go to. It was attached to the condensor fan...so I took it off and plugged it in to one of the AC lines. Still didn't work.
When I first tried it out, the AC compressor squelled for a second. I don't know what happened.
Dragonsfire
Sep 26, 2018 07:40 PM
redbug2
Jul 3, 2014 01:14 PM
