((((ABS LIGHT ON??))))
Old Feb 5, 2007 | 05:35 PM
in10ceCiviC's Avatar
Default ((((ABS LIGHT ON??))))
this morning i was driving to work and my abs light came on , why ?
my car aint braking junk, my car is running fine.........
it jus came on ? .................any things i should look for?
my car is a 92 acura gSr.....b18B block b17a head
thanks~
Old Feb 5, 2007 | 07:14 PM
BlueIntegraBoy's Avatar
Default Re: ((((ABS LIGHT ON??)))) (in10ceCiviC)
There's a malfunction in the ABS system. For what type of malfunction is beyond me. Maybe a sensor went out.
Old Feb 5, 2007 | 07:45 PM
c1rcany12's Avatar
Default Re: ((((ABS LIGHT ON??)))) (BlueIntegraBoy)
My light comes on and goes off all the time but the brake system is always working fine. I have read a lot of threads with people saying it was just a bad sensor or something got on it. Shouldn't give you a problem besides the light being annoying to look at.
Old Feb 5, 2007 | 07:50 PM
Wayne_Curr's Avatar
Default Re: ((((ABS LIGHT ON??)))) (c1rcany12)
Mine used to come on and go off randomly but now its on almost all the time. Its a code 7 I believe which I cant remember what part it is just that its caused by either that part going bad or wiring going bad.
I think my problem is due to wiring cause i'm starting to get a lot of crazy electrical problems in my car...doors locking by themselves all the time, stereo cutting out, ABS going off and on. I need to check for a bad ground I think.
Old Feb 5, 2007 | 08:25 PM
spideymangDC4's Avatar
Default Re: ((((ABS LIGHT ON??)))) (Wayne_Curr)
i have the same problem as well....only it will come on if i had turned the car off then back on...
so im thinkin its the senor...i found a thread on it a while back, showin how its done...
Old Feb 5, 2007 | 09:44 PM
Default Re: ((((ABS LIGHT ON??)))) (spideymangDC4)
what sensor is it?
if u can post a pic if not jus tell me and ill try to find it
thanks all of u ~!
Old Feb 6, 2007 | 04:39 AM
liltoua's Avatar
Here you go...hope this helps
http://www.team-integra.net/se...=1164
Old Feb 6, 2007 | 06:17 AM
teg luver17's Avatar
check your brake fluid level just to be shure my
Old Feb 6, 2007 | 08:28 AM
Tizight's Avatar
Mine goes on and off randomly.
Old Feb 6, 2007 | 11:42 AM
Speed94's Avatar
me too but it because my master cylinder is on its way out lol. When its really hot out and im at a light, the pedal will go to the floor
Old Feb 6, 2007 | 02:07 PM
j n's Avatar
j n
check your brake fluid, its probably low, and it could also be the sensor on the ebrake. did you hydroplaned that morning? i think the light kicks in if the tires lose traction.
Old Feb 6, 2007 | 05:08 PM
Default Re: (j n)
im gonna go check the fluid now.....and no i dont think i did any hydro action hahaha
my luck its probaly the dam ABS SENSOR......
Old Feb 6, 2007 | 05:10 PM
Dogginator's Avatar
Daisy... Daisy...
Have you pulled the ABS codes? They will tell you what is wrong without random guessing. There is an instruction thread in the Integra FAQ thread.
Old Feb 9, 2007 | 02:54 PM
Default Re: ((((ABS LIGHT ON??)))) (Dogginator)
thanks for the help guys....
krazyk606
Jun 15, 2009 07:32 AM
ClarkS40
Mar 21, 2009 11:59 PM
sixtodc2
Oct 4, 2007 04:15 AM
tintin11
Jan 27, 2004 01:30 PM
Hawkeye
Sep 25, 2003 09:07 AM
