blacking out your headlights
Old Feb 4, 2007 | 02:46 PM
o0Jash0o's Avatar
Default blacking out your headlights
how do i open the headlights without breaking them, i tried on my eg awhile back and it just chipped the glass. looks easy but is there a trick to doing it without destroying the headlight
want to black out the back inside
example -
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nastyda &raquo;</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>
Old Feb 4, 2007 | 03:11 PM
gsr dood's Avatar
Default Re: blacking out your headlights (o0Jash0o)
preheat ur oven to 350. when it reaches 350, shut the oven off. put ur headlights in for 10 minutes. they should peeeel rite apart. make sure alll metal parts are taken off before they go in the oven
Old Feb 4, 2007 | 04:18 PM
Import_spoon's Avatar
bump
Old Feb 4, 2007 | 04:32 PM
o0Jash0o's Avatar
Default Re: (Import_spoon)
wow never would have figured that out.....thanks
what about putting them back together. anything i need to do to make sure they seal correctly and not let water in?
Old Feb 4, 2007 | 04:38 PM
dc4teg95's Avatar
Default Re: (o0Jash0o)
sometimesyou can get away with taking a heat gun to it and reheating the glue and pressing the lens back to itand holding til it dries(couple secs). Or you can get some silicone. me and a buddy of mine did it on his 95 integra. havent had any problems with it so far. there really isnt any trick to it other then take your time with it but not so slow that the glue will harden back up
Old Feb 4, 2007 | 04:45 PM
couldn't he use those hair dryer?
Old Feb 4, 2007 | 04:47 PM
dc4teg95's Avatar
yea he could use that too doesnt really matter just so long it putsout a nice bit of heat
Old Feb 4, 2007 | 06:41 PM
be18see1's Avatar
Default Re: (dc4teg95)
look in the eg/ek forum archive. i dont remember but its one of the posts after the first one under the title "bake your headlights" or something like that.
Old Feb 4, 2007 | 07:41 PM
Default Re: (be18see1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by be18see1 &raquo;</TD></TR><TR><TD CLASS="quote">look in the eg/ek forum archive. i dont remember but its one of the posts after the first one under the title "bake your headlights" or something like that.</TD></TR></TABLE>
Would like to see the link to this.
Old Feb 4, 2007 | 07:49 PM
be18see1's Avatar
https://honda-tech.com/zerothread?id=282131
why did i look this up for you?
Old Feb 4, 2007 | 08:50 PM
DA9_DAD's Avatar
If you can spare $20 go buy some Hondabond. Its the same compound you'd use to form your valve cover gasket. Hondabond works on everything it can even make julian fries..
Old Feb 4, 2007 | 10:19 PM
Dealer Leaf's Avatar
Default Re: (DAnthony9)
can you not paint over the chrome? or do you have to bake em?
Old Feb 5, 2007 | 06:19 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by be18see1 &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=282131
why did i look this up for you? </TD></TR></TABLE>
Thanks man. I went to the EG-EK forums and i looked through 5 pages and didn't find it. I even searched Bake and headlights but nothing showed up.
Old Feb 5, 2007 | 10:19 AM
super jdm yo's Avatar
http://www.g2ic.com/forums/showthread.php?t=122320
this is the link of da one pieces. but no pics.
for me i just wanted to remove my glare guards. so i took off the clips and took that one screw and just baked them at about 225 degrees for about 10-15 min. and after a little man power they came right apart. don't put it too hot, because then the edge behind the corner light will bend and not go back to place. my buddy did that and had to cut it off so it would fit back on his car.
after you get them off i'm guessing you sand off the chrome where you want to paint it black. don't get rid of all the chrome, just the trim. because my other buddy did that and thought it was the coolest thing ever but he couldn't see five feet in front of him.
Old Feb 5, 2007 | 03:03 PM
guywitaDA's Avatar
dang... i cant believe there are still pics of my old car floating round... all i did was heat the oven to 220.... set them in there and start prying them apart at the foglight.. and slowly pull apart and you may need a knife to kinda cut the glue cause its pretty tough.... then when you want to put them back together... jsut put the back in the oven ... and let them warm back up and then put them together while they are hot... and put the clips back on.... and bang thats it
Old Feb 5, 2007 | 05:31 PM
Lscivic1999's Avatar
Default Re: (guywitaDA)
nice blades
Old Feb 6, 2007 | 09:48 AM
o0Jash0o's Avatar
Default Re: (Lscivic1999)
thanks for the info people.
anyone else has something to add go ahead, would like to know how this went for anyone else
and where do you find honda bond
Old Feb 6, 2007 | 10:02 AM
you don't need honda bond, all you need is any type of sealant that'll keep water out. i used some toilet silicon stuff and i live in seattle and i haven't had any type of leaks yet.
Old Feb 6, 2007 | 10:08 AM
yc_dc4mar's Avatar
Default Re: (trkd_out)
preheating it up to 350 wont possibly damage it right???
i just wanted to know bec i might try this on my 99 gs
Old Feb 6, 2007 | 10:17 AM
akandok's Avatar
Default Re: (yc_dc4mar)
i would attempt a cooler temperature like 250 first.. if that dont work go up to 300.. i would be afraid to melt my headlights..
Old Feb 6, 2007 | 10:27 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
A hair dryer would take FOREVER. I know because I have tried it before. A heat gun could possibly damage the lights because you would be applying very high heat to a single concentrated area.
If you use the oven, you're heating up everything evenly. If you don't go too hot (I wouldn't go over 300) then there isn't really any danger of melting anything.
Old Feb 6, 2007 | 10:29 AM
yc_dc4mar's Avatar
ok sweet thanks
big_poppa492004
Paint and Body
Aug 18, 2008 08:37 PM
Hondatron
May 12, 2007 09:10 AM
361 accord
Jan 26, 2007 02:40 PM
tehpr3chr
May 8, 2006 02:26 PM
steventsai1102
Jun 17, 2004 08:38 PM
