Is this a problem??????
Old Mar 23, 2007 | 06:31 PM
czer47's Avatar
Default Is this a problem??????
Ok im to to working on Hondas in general my background is with car audio and body work but as I began working on my new 91 teg today cleaning the engine bay/ weight reduction I found a hose on the top right driverside of the intake manifold that leads back to the bottom of the intake manifold right under the fuel behind the fuel ingectors any ways this hose is loose in the second location I tried to see why it wasnt tight I could fit a pin in between the hose and the metal could this be what is causing my fuel problems and check ingine light to come on.. All I need is to get this bitch smoged so I can really start working on it and if its not done by april 20 im selling it
Old Mar 23, 2007 | 06:33 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: Is this a problem?????? (czer47)
on obd0, and obd1 cars (yours is obd1), the check engine light will ONLY come on if there are electrical faults. It cannot cross reference mechanical faults and turn them into emissions faults. Obd2 can do that. Anyway....do you have pics of this hose?
Old Mar 23, 2007 | 06:37 PM
aaronhume's Avatar
is it your pcv valve hose? the pcv valve sits in the intake manifold under the fuel rail, and in between the left two sections of the intake manifold... a pic would be good though if you are not sure.
Old Mar 24, 2007 | 09:07 AM
czer47's Avatar
yea I think it is the pvc valve hose Thank you Im going to pick the valve up right now thanks guys
Gekko
Oct 1, 2011 05:50 AM
TURBOcrx@1.4bar
36
Jun 30, 2010 12:56 PM
gnccracer18
14
Sep 16, 2008 03:53 PM
houstondigital
Aug 29, 2005 11:48 AM
importlegions
Jun 27, 2004 02:36 PM
