help with mis fire
Old Mar 26, 2007 | 10:04 AM
pchris52's Avatar
Default help with mis fire
HELP!
ok i have a 94 b18b1
darton sleeves 2.0
golden eagle stroker kit
gsr girdle
and arp head studs
i picked up i semi built head (ls head)
just valve train an we swaped the motor....... well the swap went as most swaps do an we start it up no check engine light but the motor is lobing hard we notice that cylinder 2 an 4 are firing but 1 and 3 arent we changed dizzys spark plugs an wires still getting spark an full but lobing hard i think the head is warped an my aka friend screwed me on the deal which i will deal with later is this possible the head is warped not cause compression in these two cylinders this is a brand new built block!
Old Mar 26, 2007 | 10:26 AM
almostboostedgsr's Avatar
Default Re: help with mis fire (pchris52)
pop the cap on the distributor. Check inside to see if all the terminals are hooked properly.
Old Mar 26, 2007 | 10:36 AM
1998b18c1's Avatar
do a compression and leak down test. if thats ok try insp the injectors. goodluck
Old Mar 26, 2007 | 10:40 AM
schardbody's Avatar
wait, so is it firing and just doesnt have compression on those cylinders or what???
by the way, dont blame your friend that quick. removing the head wrong could cause it to warp, in which case it would have been fine before he took it off or whatever.
Old Mar 27, 2007 | 09:26 AM
pchris52's Avatar
Default Re: (schardbody)
its getting fire the head i found out came off a block which i just seen was from hell... the rings on it are shot so i think the only reason it even held compression to that motor was cause it warped to the block this is a fresh built bottom end an i havnt cut a corner besides this damn head which yea i should of had decked thats my bad from trusting a friend but i think its possible bent valves an extremely warped it makes no since i have no check engine light an i'm getting fuel and spark but only two cylinders are firing?
Old Mar 27, 2007 | 10:33 AM
pchris52's Avatar
Default Re: (pchris52)
bump the motor has spark and fuel an two cylinders aren't firing could it be the head? i'm think i was scammed on a warped head i mean nothin is adding up to why those two cylinders arent firing when timing and everythign is dead on?
Old Mar 27, 2007 | 11:13 AM
pchris52's Avatar
bump
Old Mar 27, 2007 | 11:58 AM
Sam92Teg's Avatar
Man, you drop tons of money on a stroked Darten sleeved block and don't even have the head pressure tested or checked for straightness on the mating surface, much less a valve job or replace valve seals, yikes.
If your getting spark and fuel to each cylinder, that only leaves compression, do a compression test. And how are you tuning this beast?
Please work on your punctuation so we can understand what your talking about.
Old Mar 27, 2007 | 12:13 PM
pchris52's Avatar
Default Re: help with mis fire (Sam92Teg)
i'm tuning s100b, its a boosted build, i know the head came from a friend who i thought i could trust, and i dont have the tools for the compression check. i'm taking a spare head i have thats in great condition an have it milled an decked smooth pressured check an a valve adjustent. i'm just checkin if a warped head could make these symptoms?
tony palo shop is down the street literally an he is goin to tune the monster when its done just tryin to get it running right with stock cams an break it in NA jsut right now......... right now i'm pullin my teeth for not milling the head the friend sold me....
Old Mar 27, 2007 | 03:06 PM
schardbody's Avatar
have you checked valve lash at all???
Old Mar 27, 2007 | 08:08 PM
pchris52's Avatar
i'm takin my spare head that i had having it milled an decked flat an doin a valve adjustment to it an trashing the other head i cant run the risk of waisting this much money on a built turbo project
Old Apr 2, 2007 | 01:31 PM
pchris52's Avatar
did the comp check the head that was on there was fucked we all got a laugh when i took the intake off an seen this friend of mine tried to port his own head it looked like with a air chizzle....... so i took my stock head up to my shop had it decked and a valve adjustmen, and put everything back together. timing is dead on an the spark plug wires were put back in by the book but the car just back fires when we try to start it???? i wish i had a stock dizzy on this but its a msd so i dont know if the msd is being gay or what???
it sounds like its 180 when i heard the back fire but i checked the plug wires an there in the right order is it possible to stab a dizzy 180 an have it flush against the head?
Old Apr 2, 2007 | 03:51 PM
pchris52's Avatar
bump
Old Apr 2, 2007 | 04:38 PM
-Kirk-'s Avatar
The map sensor and tps plugs aren't backwards are they?
Old Apr 2, 2007 | 05:51 PM
schardbody's Avatar
please tell me you checked firing order???
Old Apr 3, 2007 | 09:11 AM
pchris52's Avatar
yes i checked firing order when i crank on the motor it still pops an back fires like the plugs are backwards comp check was fine with it being a new motor and timing is dead on so wtf?
Old Apr 3, 2007 | 09:31 AM
-Kirk-'s Avatar
Default Re: (-Kirk-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -Kirk- &raquo;</TD></TR><TR><TD CLASS="quote">The map sensor and tps plugs aren't backwards are they?</TD></TR></TABLE>
Did you try to swap these plugs? It might not be the problem but they're right beside each other and are identical plugs. I've made that mistake before while doing swaps.
Old Apr 3, 2007 | 09:42 AM
pchris52's Avatar
would it start but just idle funky and throw a code right of the back???
Old Apr 3, 2007 | 02:04 PM
-Kirk-'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pchris52 &raquo;</TD></TR><TR><TD CLASS="quote">would it start but just idle funky and throw a code right of the back???</TD></TR></TABLE>
Yeah, that's exactly what it will do.
Old Apr 3, 2007 | 03:14 PM
schardbody's Avatar
what code??
Old Apr 3, 2007 | 05:54 PM
-Kirk-'s Avatar
I really don't remember which code it throws. Did you try to just swap them and see if it works? It should only take a minute to do it.
emu103
Aug 22, 2011 08:47 AM
pchris52
Apr 4, 2007 12:51 AM
gamble9465
Jan 21, 2007 06:32 AM
Tenji
Apr 22, 2006 07:23 PM
KUjonathan
Jan 15, 2004 09:10 PM
