DA owners
Old Mar 27, 2007 | 03:29 PM
90silverda1987's Avatar
From: oklahoma city, oklahoma, united states of america
Default DA owners
ok i have searched and searched for some time now and im still wondering if there is any other way to remove the alternator without having to remove the axle or drain any fluids. I just purchased my 90 integra rs and it has 85000 miles on the b18a1 but the alternator just went out and i need help. sorry im not the best when it comes to fixing cars...
Old Mar 27, 2007 | 04:40 PM
deadline's Avatar
Default Re: DA owners (90silverda1987)
sorry to say but you either need to take out the axle or the intake manifold to take it out or sell it to me
Old Mar 27, 2007 | 04:47 PM
Sam92Teg's Avatar
Default Re: DA owners (deadline)
I have heard two other ways, not sure if they work tho. You can unbolt the bracket that the alternator bolts to from the block, then if you get the alternator at the right angle, it will come up and out. The other way is to unbolt the intermediate shaft bolts and twist the bracket out of the way, then with the alt. at the right angle, it will drop out. Let us know what works for you.
Old Mar 27, 2007 | 06:14 PM
IHTFP's Avatar
i just did this this summer...no removing axle or draining fluids..
pop the lower ball joint, and as a whole unit, swing the knuckle/rotor/caliper/axle out and to the right. you'll be pulling the axle out of the intermediate shaft but leaving it through the hub and swinging the whole unit out of the way, if you can understand that.
change alternator and install is just the reverse.
oh and get a helms itll tell you how to do it step by step and it involves removing the axle, its really not that bad. a friend is always helpful too
Old Mar 27, 2007 | 11:21 PM
brian L.'s Avatar
Default Re: DA owners (IHTFP)
bro you don't need to take out the axle or the intake manifold.I know it looks like theres not much room but you could do it.
Old Mar 28, 2007 | 12:20 AM
Lord Helmet's Avatar
I have taking the alt through the top and bottom without removing the axles. only thing I removed to get it through the bottom was the exhaust manifold down pipe. easy as pie
Old Mar 28, 2007 | 02:03 AM
DAJunkie90's Avatar
yeah, I have seen someone on G2IC.com do it. You do not have to remove the axle or manifold. According to what I saw, you just unbolt the halfshaft and that should give you the room needed to get it out. Or you can just check out the website!! There are picks of the procedure.
Old Mar 28, 2007 | 01:47 PM
i unbolted all the bolts holding the brace on the engine block but its getting stuck at the bottom of the by the driver side axle. but by reading your post i think i can squeeze it out. I just gotta find the right angle. is removing the exhaust downpipe hard? or should i try a different method?? THANKS FOR THE HELP.
. M i c h a e l
Mar 28, 2018 03:57 AM
GoodEyeSniper
Feb 19, 2009 02:21 PM
MR_Se7en
Mar 25, 2008 10:04 AM
ge_itr
Nov 28, 2006 06:08 AM
97VtecIN
Nov 7, 2004 08:52 AM
