ecu reprogramming
Old Mar 26, 2007 | 03:55 AM
jlfrnce's Avatar
Default ecu reprogramming
can anyone point me into the direction of someone that can reprogram the stock 94 ls ecu to run vtec, and what is a good price should i be looking to pay for this. thanks for the advice every1
Old Mar 26, 2007 | 06:35 AM
mc-integra111's Avatar
Default Re: ecu reprogramming (jlfrnce)
I am not even sure if thats possible, but I don't know. Try http://www.xenocron.com/.
Old Mar 26, 2007 | 07:38 AM
mmuller's Avatar
Mad Scientist
yep it can pretty easily be done and turns it into a p72
Old Mar 26, 2007 | 08:26 AM
pvt_awol's Avatar
Default Re: ecu reprogramming (mmuller)
R U sure it makes it into a P72? Just because you add the VTEC circuitry, doesn't mean that the KNOCK SENSOR circuitry will automatically start working. Without the knock sensor, it's nothing more than a p28.
A lot of shops will charge a lot to convert over to VTEC. Might be better off picking up a 100 dollar P28 instead. Then pay to have that chipped. Then it's only like 30 to 50 bucks. (tuning is extra of course)
Hondata will modify your ECU for you for VTEC, if that is what you want though. There are a ton of other shops around that will do it also, for cheaper, but Hondata is reputable, and they will stand by their work.
Old Mar 26, 2007 | 09:03 AM
iH8RICERZ's Avatar
Default Re: ecu reprogramming (pvt_awol)
go to phearable.net and ask him. It won't cost too much...then again, it might be easier and cheaper just to get a reprogrammed p05/p06 ecu that has been converted to vtec.
Old Mar 26, 2007 | 09:13 AM
fergy016's Avatar
Default Re: ecu reprogramming (iH8RICERZ)
I would only reprogram my ecu on a dyno, call around to dyno's around you that you would feel safe tuning your car at. They will usually have the ability to re-chip and program the ecu.
Old Mar 26, 2007 | 11:05 AM
jlfrnce's Avatar
Default Re: ecu reprogramming (fergy016)
well i dont have that kind of cash yet for a hondata, figured i seen ecu's that were chipped for like 200 so i fig'd i could just get mine done to save some cash. guess i am just gonna have to wait and find a stock obd1 p72 ecu to run the engine.
Old Mar 26, 2007 | 11:36 AM
pvt_awol's Avatar
yeah, I wasn't saying to buy a hondata system, I was just saying to have them socket your ecu for you, so you could chip it.
Old Mar 26, 2007 | 11:38 AM
iH8RICERZ's Avatar
which motor are you going to have?
Old Mar 26, 2007 | 01:18 PM
mmuller's Avatar
Mad Scientist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pvt_awol &raquo;</TD></TR><TR><TD CLASS="quote">^
Hondata will modify your ECU for you for VTEC, if that is what you want though. There are a ton of other shops around that will do it also, for cheaper, but Hondata is reputable, and they will stand by their work. </TD></TR></TABLE>
i was not counting the knock board which you can also add if you like. i was talking more about the boards and iab control
Old Mar 26, 2007 | 01:58 PM
fergy016's Avatar
Don't do the job 1/2 way. Save up and do it the right way. Putting your car on a dyno will be the only way to get an ecu set-up for your specific application instead of a band aid that will give you more power, but may give you lean spots and harm your engine in the long run.
Old Mar 26, 2007 | 05:25 PM
jlfrnce's Avatar
Default Re: (fergy016)
ok i bought a 1994 ls chassis and a 01 gsr egine and ecu. i can wire in the knock and the 2nd O2 if i have too but wont matter to me. only mods for egine is cai, header, high flow cat and no res on it,(previous car owner took it off) i am just looking to get it to run right for now!
Old Mar 26, 2007 | 05:31 PM
iH8RICERZ's Avatar
Default Re: (jlfrnce)
yeah, your better off just gettin a stock p72 (gsr ecu) at this point.
Old Mar 26, 2007 | 05:43 PM
jlfrnce's Avatar
Default Re: (iH8RICERZ)
but wouldnt i save money if i can get this 1 converted and chipped to run vtec or no?
Old Mar 26, 2007 | 06:33 PM
pvt_awol's Avatar
I don't think you would save money. I think that a chipped P28, or stock OBD-1 P72 would be the route to take.
really quick, about the intake butterflies, are you going to use them? Did you add the wiring for them?
Old Mar 27, 2007 | 03:57 AM
jlfrnce's Avatar
Default Re: (pvt_awol)
yes already ran wires into the car, even ran the knock sensor but guess i can take it back out(?) but still have to fig our wire conversion for the dist.
Old Mar 27, 2007 | 08:32 AM
PissedoffB20's Avatar
the knock sensor on are cars does not really work all that well so big deal, have it socketed, converted to vtec, tehn when the programing is done have them disable the knock all together. although you have to understand that there is a different process to make that ecu able to run the GSR intake manifold too. so either dont run that manifold or make sure previsions were set with in the ECU to run the iab's as well.
That being that case a lil more info on the subject. The h22 and gsr were the only engines to use that style manifold and an h22 ecu just wont cut it so im sure you can se where im goign with this. Your options are limited but at the same time theres a few was to go about dealing with our setup.
Old Apr 2, 2007 | 04:17 AM
jlfrnce's Avatar
Default Re: (PissedoffB20)
think i am just gona order a new ecu this weekend from http://www.xenocron.com that is already chipped and all be done with.
qazaq
Nov 28, 2006 11:42 AM
Shmaa
Oct 30, 2006 11:48 AM
RTW DC2R
Apr 4, 2006 09:42 PM
sk8phaze
Jun 5, 2003 09:55 AM
intezn
Jan 27, 2003 11:40 PM
