Caliper help
alright, so i need a oem replacement caliper for my gs-r (rear passenger), so i went to autozone.
i purchased two refurbished ones, and BOTH caused my e-brake to lock up, and not release when i released it.
and no, the cables were good, they were not stiff at all, the spring on the caliper was not clicking over to return my wire back to a relaxed position.
1.) i am posting this so no one goes to auto zone to purchase a caliper ever again
2.) i wanna know where i can get one for a fair price, and also how much would a upgrade in a nice caliper set for all 4 wheels cost me?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by numbnuts22715 »</TD></TR><TR><TD CLASS="quote">you could find one at a junkyard.
and if you want an upgrade, fastbrakes.com has some good stuff, complete with everything you need.... pads, calipers, brake lines, rotors
hard to find integra parts at a junk yard where im at.
all the good stuff is taken days before you get there
</TD></TR></TABLE>hard to find integra parts at a junk yard where im at.
I have an Autozone reman rear driver's side caliper and it has been fine for over 60K miles.
IMHO:
Stock brakes don't need better rotors, but better pads.
The use of slotted and drilled rotors are a much debated topic on these forums. Many racers use cheap stock sized Autozone rotors (I just bought one, $20 for front driver's) but run upgraded pads and brake fluid. They maintain the only better rotor than stock is one with a larger diameter mated to a larger caliper -- and blank, not slotted or drilled.
IMHO:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sam92Teg »</TD></TR><TR><TD CLASS="quote">I have an Autozone reman rear driver's side caliper and it has been fine for over 60K miles.
IMHO:
The use of slotted and drilled rotors are a much debated topic on these forums. Many racers use cheap stock sized Autozone rotors (I just bought one, $20 for front driver's) but run upgraded pads and brake fluid. They maintain the only better rotor than stock is one with a larger diameter mated to a larger caliper -- and blank, not slotted or drilled.</TD></TR></TABLE>
x2
i have autozone blanks, and hawk ceramic pads.
I guess i just got bad luck...im heading over to a different automotive store today to see if i can find one there that works.
btw, i would never, ever recommend getting a caliper from a junk yard... but thats just imo
IMHO:
x2
FuNkDrSpOt
Jul 5, 2006 06:33 PM
NTGR8D
20
Mar 17, 2005 04:09 PM
BlownVR
13
May 17, 2004 01:05 PM
