help!!
Old Mar 27, 2007 | 02:33 AM
agent1471's Avatar
Default help!!
i drive a 98 gsr, i recently lowered my car. after a few weeks i started to notice that the front of my car starts to make a sqeeking noise. The noise i am hearing coming from the front of my car, sounds like when your breaks are worn, but these sounds occurs when i am not even stepping on the breaks.. more like when im turning.. or slowly driving my car.
Old Mar 27, 2007 | 02:43 AM
suzawa94's Avatar
Default Re: help!! (agent1471)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by agent1471 &raquo;</TD></TR><TR><TD CLASS="quote">i drive a 98 gsr, i recently lowered my car. after a few weeks i started to notice that the front of my car starts to make a sqeeking noise. The noise i am hearing coming from the front of my car, sounds like when your breaks are worn, but these sounds occurs when i am not even stepping on the breaks.. more like when im turning.. or slowly driving my car.</TD></TR></TABLE>
well, if it wasn't squeaking prior to the drop it probably had something to do with the installation of the drop. suspension squeaks are caused by bad/worn bushings.
in order to narrow down your diagnosis, spray some lube on each bushing and see if it goes away. upper and lower control arm, sway bar and steering rack mounts are some areas where you would want to start. after that take a road test that would duplicate the squeak. it's not the most time effective way, but it will definately lead you to the problem i would help alot if you can narrow the sound from the LF or RF.
1994PreludeSi
Dec 19, 2007 07:58 AM
My97lude
Jul 12, 2007 10:32 PM
L-Dawg
Honda Civic (2006 - 2015)
20
Feb 18, 2007 10:24 AM
vi3tromanc3r
12
Nov 9, 2006 02:45 PM
el arbi
15
May 18, 2003 09:06 AM
