DA is howling!?
Old Mar 27, 2007 | 11:26 AM
int3gra07's Avatar
* B A N N E D *
Default DA is howling!?
This happens when I first start the car and the morning or after work. When I slightly turn the steering wheel, I hear somewhere in the engine a mid high pitched howling sound. It sounds for about 3 seconds then goes away for good. The best way I can describe the noise, is like a small dog crying.
I checked my power steering reservoir and thats topped off. Any of you G2 owners ever get this? What could be the problem?
NARC
Old Mar 27, 2007 | 11:41 AM
Sam92Teg's Avatar
Default Re: DA is howling!? (int3gra07)
Power steering belt slipping possibly?
Old Mar 27, 2007 | 01:16 PM
int3gra07's Avatar
* B A N N E D *
Default Re: DA is howling!? (Sam92Teg)
Don't think so. It still makes sounds before and after I removed all the belts when I did my timing belt.
Old Mar 27, 2007 | 01:53 PM
SpdJnky91's Avatar
Maybe you have a small dog stuck i there! lol! I remeber when I worked at Jiffy Lube this lady had a cat stuck behind her engine. It was crazy cause the body was frozen stiff and all it could do was move it's head!
Old Mar 28, 2007 | 05:25 AM
int3gra07's Avatar
* B A N N E D *
Default Re: (SpdJnky91)
anybody?
Old Mar 28, 2007 | 05:55 AM
lacking vtec's Avatar
mine does that when it gets real cold outside. it's warmer now so it doesnt do it anymore. i dunno what it is either, could be the belts
Old Mar 28, 2007 | 06:24 AM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpdJnky91 &raquo;</TD></TR><TR><TD CLASS="quote">Maybe you have a small dog stuck i there! lol! I remeber when I worked at Jiffy Lube this lady had a cat stuck behind her engine. It was crazy cause the body was frozen stiff and all it could do was move it's head!</TD></TR></TABLE>
whoawhoawhoa, you gotta elaborate on that one...
Old Mar 28, 2007 | 06:32 AM
96WhiteOnBlack's Avatar
I dont know what it could be since you replaced the belts. But I can tell you how to temprarily fix it. While the motor is running... spray some wet tire shine on the belts. Just one good spray for each and it will be gone instantly! I've done it several times on several cars.
Old Mar 28, 2007 | 09:42 AM
91redteg's Avatar
Default Re: DA is howling!? (96WhiteOnBlack)
my toyota tacoma used to do that. power steering fluid might be low? i refilled mine and the sound went away
Old Mar 29, 2007 | 08:28 AM
int3gra07's Avatar
* B A N N E D *
Default Re: DA is howling!? (91redteg)
I already checked the reservoir.
Old Mar 29, 2007 | 08:37 AM
RedB20DA's Avatar
Your pump may be going bad... they usually start to make a whinning noise and eventually it will get louder and longer.I ditched my power steering so i dont have that problem!
Old Mar 29, 2007 | 08:39 AM
int3gra07's Avatar
* B A N N E D *
Default Re: DA is howling!? (RedB20DA)
Thanks for your help guys. your right, bad pump
Old Mar 29, 2007 | 09:13 AM
Sam92Teg's Avatar
You said it was making the noise even after you removed all the belts. How can a power steering pump make noise if a belt isn't spinning the pulley?
ddrayful
Mar 6, 2014 04:58 AM
oscarlx
Jun 26, 2012 09:26 AM
alexsneesby
May 14, 2010 05:18 AM
DC206R
May 4, 2009 01:43 PM
92accord95jdmh22a
Apr 24, 2004 10:22 AM
