Block Drain Plug?
Old Mar 27, 2007 | 09:40 PM
gotboost562's Avatar
Default Block Drain Plug?
I will be replacing the radiator in my car soon. I have heard there is a drain plug in the block that needs to be removedin order to drain the remaining coolant out of the block. Where exactly is this plug? Does anyone have pics? Is it really necessary?
Old Mar 27, 2007 | 09:50 PM
1998b18c1's Avatar
Default Re: Block Drain Plug? (gotboost562)
no dont mess with block at all. just r&r rad. and bleed the coolant from the small bleeder on the water outlet that goes from the head to the rad(top rad hose.) use the acura or honda type 2 coolant its premixed and it holds to form real well. its only $13.00, you may need 2 to flush all the old coolant out. goodluck
Old Mar 31, 2007 | 10:44 PM
Default Re: Block Drain Plug? (1998b18c1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1998b18c1 &raquo;</TD></TR><TR><TD CLASS="quote">no dont mess with block at all. just r&r rad. and bleed the coolant from the small bleeder on the water outlet that goes from the head to the rad(top rad hose.) use the acura or honda type 2 coolant its premixed and it holds to form real well. its only $13.00, you may need 2 to flush all the old coolant out. goodluck
Thanks for the reply. Where exactly is the bleeder screw? I looked all over and didn't see it. This is on a b-series. Maybe I just overlooked it.
Old Apr 1, 2007 | 07:31 AM
sauceja's Avatar
I don't know I drained my block yesterday to remove the head and there was some junk in there that wasn't in there last year when I put the head on after I rinsed block out.
If it is a bseries look about 5 inches to the right of where it says B1xxx and you will see a 19mm bolt. It is to the left of exhaust manifold.
Remove that and you can drain the block.
m.glisson003
Dec 15, 2011 04:27 AM
atikovi
Oct 7, 2010 05:49 PM
mikestypeRR
Nov 17, 2005 01:11 PM
Paprika
16
Dec 11, 2004 12:38 PM
XxslayerxX
27
Oct 19, 2003 11:33 AM
