hondata knock sensor problem
Old Jun 17, 2007 | 11:02 AM
c1civic's Avatar
Default hondata knock sensor problem
well, i have a 96 gsr with bolt ons and I throw no codes at all. Using the obd2 to obd1 adapter harness, i also have hondata s300. When i install it i throw a code for my knock sensor. It also pulls the timing quite a bit. When I plugmy old ecu in, there is no problems. I know i can disable to the knock sensor. I tried to do it and the cel went away and no timing was pulled. Should i just disable the knock sensor or do i have to be concerned about what it is. Any input is appreciated. I would have posted in hondata forums, but having issues with my account
Old Jun 17, 2007 | 12:03 PM
numbnuts22715's Avatar
yes, you should disable it.
for starters the honda knock sensor is worthless, so its pointless to even have it.
I have read that it starts to ignore the knock sensor at higher rpms, and that's when all the problems will start from detonation and whatnot.
If you're worried about knock, check into the J and S safeguard... its a good knock sensing device.
Old Jun 19, 2007 | 11:17 AM
Spunkster's Avatar
Default Re: hondata knock sensor problem (c1civic)
What ecu is the s300 installed in?
monty Si-R
Apr 25, 2007 05:26 PM
TurbodTegSfaria
Feb 27, 2007 03:57 PM
beef-cake
Feb 19, 2006 03:38 PM
92ludeport
Jul 8, 2005 02:08 PM
BoostedGSRBubble
Jan 17, 2003 10:27 PM
