vtec hitting late?
Old Jun 18, 2007 | 04:06 PM
phish4709's Avatar
Default vtec hitting late?
i was taking my car out today with a friend... and i usually never hit vtec cause gas is so damn expensive but he wanted to hear it...... it seems to hit fine at 4.4k but i can only hear the secondary butterfly's hit at 6? is there something that i need to check..oil is fine that's the only thing that came to my mind
Old Jun 18, 2007 | 04:11 PM
posHonda's Avatar
stock?? its a lot easier to hear the secondaries open than vtec engaging
Old Jun 18, 2007 | 04:17 PM
Padawan's Avatar
Darth ModerVader
Default Re: vtec hitting late? (phish4709)
I'm not really sure what you're asking. You said that VTEC engages at 4400 (which it should), and you can hear the secondaries open around 6000 (5750 is the correct RPM). It seems as if everything is functioning as it should.
Old Jun 18, 2007 | 04:18 PM
phish4709's Avatar
Default Re: vtec hitting late? (Padawan)
alright just checking lol and yeh the car is completely stock
Old Jun 18, 2007 | 09:00 PM
martyball619's Avatar
u cant hear vtec on a stock gsr
Old Jun 18, 2007 | 09:07 PM
alexisthemovie's Avatar
if you want to hear your vtec engage on a stock gsr, open up your airbox and run open header.
Old Jun 19, 2007 | 02:42 AM
OC Geezer's Avatar
You can BARELY hear it if you listen carefully.
But according to your description, everything is as it should be.
TastyDragon
Oct 25, 2006 04:12 PM
90teg
Jan 5, 2006 03:09 PM
xxsupcuhzxx
Dec 7, 2005 11:39 AM
Bonzai1994
Aug 16, 2005 03:32 PM
GreenGSR
Aug 11, 2002 06:45 AM
