code 43..car drives fine..wtf
Old Jun 17, 2007 | 01:11 PM
rorik's Avatar
Default code 43..car drives fine..wtf
Yes, I searched, nothing.
Ok, so I looked this up elsewhere and it's supposedly the code for fuel supply system malfunction. Is that right? 95 ls. The car drives the same as it always has. So how does this code set? The ecu detects a variance in the 02 output in closed loop with the same injector pulse width, or what? How can it tell the difference between that and a fucked up 02 sensor? I don't get it, but I'm about to start checking the fuel press, etc. Any knowledge/experience on this is welcome here..
thanks
Old Jun 17, 2007 | 03:02 PM
g0tgot's Avatar
Default Re: code 43..car drives fine..wtf (rorik)
try cleaning the sensor....always first thing i would check to make sure it is reading properly....
Old Jun 18, 2007 | 09:22 AM
rorik's Avatar
you mean the 02 sensor? it has under 10k miles on it..
Well, I guess it's time to start being a grease monkey instead of posting up on here about it..
Old Jun 18, 2007 | 02:40 PM
big22's Avatar
Default Re: (rorik)
had the same code on my 95 ls, replaced the o2 and all good now.
Old Jun 18, 2007 | 02:53 PM
Red4drLSintegra's Avatar
i had the same code also..replaced the 02 sensor..and its been fine
Old Jun 19, 2007 | 10:13 AM
rorik's Avatar
just replaced the fuel filter, still get the code, guess the 02 might be next..
jrwhites
Jul 15, 2008 03:37 PM
existanzcivicb20
Feb 8, 2008 04:27 PM
b18_crx
Oct 27, 2005 05:19 AM
