Maintenance question?..
Old Jun 18, 2007 | 02:01 PM
VTECth1s's Avatar
Default Maintenance question?..
Soon Ill be getting either a gsr or b16 long block from a reliable and trustworthy friend of mine for my DA9. What should I replace as for maintenance on the engine, say if the motor was past due on maintenance from the previous owner. This is the list of things I would change, anyone else please chime in for more info. TIA!
-Compression/leak down test
-Oil change
-Change spark plugs
-Change spark plug wires
-Change oil pump
-Change water pump
-Change timing belt
-Valve adjustment
-Change transmission fluid?
Anything else I am missing out?
Old Jun 18, 2007 | 02:05 PM
numbnuts22715's Avatar
rotor, distributor cap.
Old Jun 18, 2007 | 02:06 PM
doood's Avatar
been there done that
Default Re: (numbnuts22715)
cam seal
vtec solenoid gasket
valve cover and plug hole gaskets
valve seals if your leakdown numbers come back bad
Old Jun 18, 2007 | 05:00 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: Maintenance question?.. (VTECth1s)
You normally flush the coolant when you replace the water pump.
If your cooling system hoses aren't that new, I would replace them at this time. All of them. Good preventive maint.
Old Jun 19, 2007 | 05:34 AM
VTECth1s's Avatar
Default Re: Maintenance question?.. (nsxtasy)
Thanks guys, appreciate the good info
Old Jun 19, 2007 | 12:30 PM
ALF's Avatar
ALF
Don't forget the PCV.
And clean out the IACV.
Old Jun 19, 2007 | 02:46 PM
VTECth1s's Avatar
Default Re: Maintenance question?.. (ALF)
IACV is pita to get into my first time cleaning it.
Old Jun 19, 2007 | 04:00 PM
OC Geezer's Avatar
Your thermostat could be changed while you're at it.
Maybe the headgasket and seals.
MachAF
Jul 22, 2005 01:35 PM
jeremy.
Feb 8, 2005 10:42 AM
BLK99VTECR
Mar 1, 2004 11:10 AM
jdmgeorge
Feb 18, 2004 12:45 PM
boostincoupe
Jul 1, 2003 12:38 PM
