hey need help..on Swapping and engine
Old Jun 14, 2007 | 05:21 PM
aeenox's Avatar
Default hey need help..on Swapping and engine
i just got a DA shell a project car to learn how to do stuff on it...is there like a sticky or something that u guys know about that 1st of all explains how to built a Ls/ Vtec?...and second is there one that explains how to install a motor into the DA?...cause im thinkin of doin it myself cause i wanna learn how and also i think it will some out cheaper...so yea ??????
Old Jun 14, 2007 | 05:26 PM
doood's Avatar
been there done that
Default Re: hey need help..on Swapping and engine (aeenox)
you can find them by using https://honda-tech.com/zerosearch
Old Jun 14, 2007 | 06:25 PM
Sam92Teg's Avatar
https://honda-tech.com/zerothread/1676914
Old Jun 14, 2007 | 06:35 PM
Blahblah718293's Avatar
Default Re: hey need help..on Swapping and engine (Sam92Teg)
i dunno if an engine swap is somthing you should try yourself for the first time. i know i wouldnt try it after investing all the money in the shell and motor. id be too afraid to mess somthing up.
Old Jun 14, 2007 | 07:04 PM
RS'R''s Avatar
go for it. take your time and make sure you have the right tools and the help of someone more experienced. you learn best by doing it yourself! gotta start somewhere and engine swaps if you keep it in the same odb and engine series aren't that hard. i wouldn't take on lsvtec right away though. swap in a GSR or b18a/b
Old Jun 14, 2007 | 10:27 PM
CompanyFlow's Avatar
I wouldnt try to take on a task as big as an engine swap if you cant even use the search function.
Old Jun 14, 2007 | 10:29 PM
numbnuts22715's Avatar
Default Re: hey need help..on Swapping and engine (CompanyFlow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CompanyFlow &raquo;</TD></TR><TR><TD CLASS="quote">I wouldnt try to take on a task as big as an engine swap if you cant even use the search function.</TD></TR></TABLE>
rofl, that really made me laugh
check out the hybrid section, and search a lot.
an lsvtec can be really good, but if you dont know what you're doing, it can end up really bad for you.
Old Jun 17, 2007 | 07:49 AM
aeenox's Avatar
well the shell i got for free....and imma just swap in a gsr engine cause i got hook ups and imma just end up doin that and imma just do it myslef ..cause the car is just gonna be sittin here ..i dont even really need the car i just got it to learn how to work on it ...and imma just use it as a track car ..cause i have my 06 si to drive around
Old Jun 17, 2007 | 07:51 AM
aeenox's Avatar
how come someone always has to talk crap about people not using search function....the search fuction is this place sucks *** ....
Old Jun 17, 2007 | 11:13 AM
Default Re: (aeenox)
So you admit you didnt search then? If so, nobody should be helping you from this point forward. This is probably the most general and most widely asked question, and you didnt even search one time.
Old Jun 17, 2007 | 11:16 AM
doood's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aeenox &raquo;</TD></TR><TR><TD CLASS="quote">the search fuction is this place sucks *** ....</TD></TR></TABLE>
the search works fine. the searcher is the one that sucks ***.
aeenox
Jun 14, 2007 05:30 PM
tonyb18b1-T
May 20, 2006 03:10 PM
out_of_order
12
Mar 10, 2004 11:55 AM
kuelerz
Aug 13, 2002 01:05 PM
