bad lsd
Old Jun 18, 2007 | 12:48 PM
Baron55's Avatar
Default bad lsd
So, i pull out of a gas station and wasing gently accelerating through 1st when the car just started reving as if i was in neutral even though it was still in 1st. I pull over and couldnt get it moving after. Oil was coming from where the axles go in the tranny. If i put the car in gear and give it gas, the speedo would rise but car goes no where. I was told my lsd messed up...I bought a jdm type r lsd from jdmland.com.
Any ideas why this would fail on me?
Old Jun 18, 2007 | 02:09 PM
numbnuts22715's Avatar
Is the lsd currently in there the jdm type r lsd?
Or did you buy a new type r lsd to replace it.
Reasons for messing up could be something like improper install, or something like that.. Usually theyre pretty durable.
Old Jun 18, 2007 | 04:22 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: bad lsd (Baron55)
Your axle most likely popped out of the differential. Since the speedometer is indicating a speed, the differential is turning. The helical ITR LSD acts like an open differential when one wheel has zero traction.
Old Jun 18, 2007 | 05:42 PM
Baron55's Avatar
yeah its a jdm type r lsd
Old Jun 19, 2007 | 04:22 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: (Baron55)
From the IM that you sent to me:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Baron55 &raquo;</TD></TR><TR><TD CLASS="quote">has your lsd ever give you problems? This friday i pull out of a gas station and wasing gently accelerating through 1st when the car just started reving as if i was in neutral even though it was still in 1st. I pull over and couldnt get it moving after. Oil was coming from where the axles go in the tranny. If i put the car in gear and give it gas, the speedo would rise but car goes no where.</TD></TR></TABLE>
This definitely sounds like the axle popped out. You may want to replace the set ring for the axle. Hopefully the axle seal was not damaged.
jazmie
Transmission & Drivetrain
Feb 1, 2010 10:20 PM
GT30RSX
Mar 1, 2007 03:29 AM
shadowz
Apr 11, 2004 08:59 AM
