Need Help!! Changed Dash Harness ran into some problems
Old Jun 18, 2007 | 07:13 PM
T_bones's Avatar
Default Need Help!! Changed Dash Harness ran into some problems
I have a 95 Acura Integra LS I am currently replacing the Dash Harness with a 97 Integra Harness cause my other one has been cut in so many spots.
I plugged the 3 Plugs from the dash harness into the Fuse Box and plugged the hazard button up along with the gauge cluster just to check to make sure everything was working right.
Stuff that isnt working now since I changed the harness.....
My power windows will not roll up
My Turn Signals will not work
My Sunroff will not open/close
My Brake lights will not work when pedal is pushed in
I switched back the harness just to see if it would fix it but only thing that started working was the turn signals when I did that.
Anyone know what the problem could be?
Old Jun 18, 2007 | 09:08 PM
T_bones's Avatar
any1
Old Jun 18, 2007 | 11:36 PM
T_bones's Avatar
Default Re: (T_bones)
I believe I fiqured out the problem....
I compared both harness to each other. Only difference was that the Yellow/Black pin which deals with hazard switch needs to be taking from the Green Plug
(the one that plugs into cars fuse box)from the 97 Harness and put into the Grey Plugs Empty Slot(should only be one empty slot on bottom right corner). After doing this is makes the 97 Harness exactly the same as the 95 Harness. As for the Brake lights not working I blew the horn fuse today the one located under the hood fuse box. Which is controls both horn/taillights.
Will let yall know if everything turns out good 2mar.
Old Jun 19, 2007 | 05:08 PM
T_bones's Avatar
Yep that was the problem. Everything is fixed and working great
D_koschak
Mar 23, 2016 11:14 PM
V/\ freestyle
Mar 13, 2011 08:52 PM
tdizz07
Jan 11, 2010 04:58 AM
coolguy660
Aug 30, 2006 09:45 PM
