INTAKE VALVES
Old Jun 14, 2007 | 08:20 PM
DUNKLEYMOTERSPORTS90T's Avatar
Default INTAKE VALVES
hello all i was wandering and i was told that if i was to turn the intake cam i notch on the gear on the timing belt it would give me more peformance is this true ?? i got a 91 acura integra 1.8 dohc ? thanks and is this true on all dohc moters thanks again TONY
Modified by DUNKLEYMOTERSPORTS90T at 10:16 PM 6/14/2007
Old Jun 14, 2007 | 08:48 PM
turbob16b's Avatar
Default Re: INTAKE VALVES (DUNKLEYMOTERSPORTS90T)
sounds like someone's messin with you
Old Jun 14, 2007 | 08:51 PM
93JDMB18C's Avatar
Default Re: INTAKE VALVES (turbob16b)
Explain in more detail...maybe you are trying to say something you are not quite getting across???
Old Jun 14, 2007 | 09:11 PM
numbnuts22715's Avatar
If you mess with it, it could affect the driveability of your car.
It may not idle right, or something like that...
Theyre supposed to be where theyr'e at. Leave them there.
Old Jun 14, 2007 | 09:15 PM
Default Re: INTAKE VALVES (93JDMB18C)
when linning up the timing marks on the cam gears anvance the intake cam gear i notch then put the belt on ? that what i got told to do.will the increce the performance?? thanks
Old Jun 14, 2007 | 09:25 PM
b20integrapower's Avatar
You can advance timing via distributor I believe, but that is it. If you are off just one tooth your car will run like shiat.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DUNKLEYMOTERSPORTS90T &raquo;</TD></TR><TR><TD CLASS="quote">when linning up the timing marks on the cam gears anvance the intake cam gear i notch then put the belt on ? that what i got told to do.will the increce the performance?? thanks </TD></TR></TABLE>
I thought I just told you?
Do you have adjustable cam gears?
Do you even know what advancing the cam timing does?
Do you have a dyno to test how much power you are gaining or losing?
Do you have an EGT gauge to show you how the changes you are making are affecting your car?
Old Jun 14, 2007 | 09:44 PM
Default Re: INTAKE VALVES (numbnuts22715)
thank you all... i will leave it where it is.. thanks all for your help
vacantskies88
18
Dec 5, 2007 02:05 PM
integlstrike1
Aug 22, 2006 07:24 PM
2000fbp
Aug 27, 2003 09:19 PM
Mr.Integra
May 22, 2003 12:41 AM
slowman
Nov 29, 2002 05:27 PM
