Idle problems
Old Nov 12, 2007 | 07:44 AM
jarredm's Avatar
Default Idle problems
Ok. i just tried and failed to install an aftermarket intake manifold. I failed to realize the need for new injection, new fuel rail, fuel reg, hondata, and the simple yet expensive tuning of the car. anyone who has tried this knows its a pain in the butt! so i had my stock intake manifold put back on. ok. now every time you start the car the rpms go right to about 3000 and hold for about 5-8 seconds, then drop to 1000 and continuiously go from 1000-2500 and repeats without stopping. i tried replacing the map sensor and that wasn't it. does anyone have or has anyone had this problem and can tell me what the heck is going on with my car? its really ok, just anoying when your at a stop light or sitting somewhere with the car running. i don't think it would be the tps sensor because this is a constant idle between two points and it would't be that constant with a tps problem. so does anyone know what the heck is goin on?
Old Nov 12, 2007 | 08:12 AM
TurdBlown Teg's Avatar
unplug the tps and see if it idles nomally
Old Nov 12, 2007 | 08:38 AM
jarredm's Avatar
we unpluged it and it ran really funny. so i don't think that is it.
Old Nov 12, 2007 | 11:34 AM
jarredm's Avatar
Default Re: (jarredm)
anyone else know what could be goin on?
Old Nov 12, 2007 | 03:40 PM
DAchiko's Avatar
sorry i got the same problem looking for the answer i have a skunk 2 intake manifold maybe it has something to do with that i dont know?
Old Nov 12, 2007 | 04:27 PM
CarFreek's Avatar
Default Re: (DAchiko)
I had a friend that had a CRX with a B16 that had that problem,
And a friend with a 90 DA that did the same thing.
In the DA it was a bad idle air control valve.
And in the CRX it was a little screw in the throttle body that came lose.
I would get you more info if i still had either of their phone numbers,
But i don't sorry.
Old Nov 12, 2007 | 07:37 PM
idle air control valve is on back of the mannifold see if thats it also with the little screw thats the tps sensor
ScottF
Jun 8, 2010 03:55 PM
e30FTMFW
Sep 26, 2008 10:42 AM
mikeunreal
Oct 27, 2005 02:39 PM
SupaFly_Honda
Feb 26, 2004 05:12 AM
baonest1
Aug 17, 2003 05:51 PM
