idle up and down
Old Nov 12, 2007 | 03:34 PM
DAchiko's Avatar
Default idle up and down
my car starts fine but after it warm and and i run it for a while it starts idling up and down it doesnt rev too high maybe till 2k any\ suggestions will help .. thanks
Old Nov 12, 2007 | 03:47 PM
Slyfox_racer's Avatar
Default Re: idle up and down (DAchiko)
check your wireing and then check your tps sensor
if that doesnt work there the favc and the other thing
i cleaned mine out still had the same problem
checked my wireing and my tps was wired wrong
and my tps is bad i still need a new one
Old Nov 12, 2007 | 03:48 PM
champLSinteg's Avatar
try spraying some carb cleaner on the throttle body and intake to head gaskets. if the idle changes when you spray a certain area thats were you have a leak. might be a throttle body gasket.
Old Nov 12, 2007 | 04:28 PM
CarFreek's Avatar
Default Re: idle up and down (champLSinteg)
I had a friend that had a CRX with a B16 that had that problem,
And a friend with a 90 DA that did the same thing.
In the DA it was a bad idle air control valve.
And in the CRX it was a little screw in the throttle body that came lose.
I would get you more info if i still had either of their phone numbers,
But i don't sorry.
Old Nov 12, 2007 | 06:43 PM
killah1's Avatar
hey try messing with the air bypass valve its the thing under ur throtle body take it off an take the screws off an tighten its an it should work just fine
DO/\/\O
Jul 26, 2011 01:44 AM
feriotypeR
Oct 10, 2009 03:58 AM
91 ef hatchback
Jun 9, 2007 11:26 AM
bdicustoms
Jun 2, 2003 03:47 AM
FourthGenHatch
Apr 29, 2002 11:08 AM
