Backfire! NEED HELP!
Old Nov 9, 2007 | 11:29 PM
JaayDeeM's Avatar
Default Backfire! NEED HELP!
Ok, so I am having a problem. I was driving my car around pretty hard through the country raods awhile back and all of the sudden, whille I had my foot to the floor...it's started to backfire repeatedly and would not accelerate. I could accelerate if I didn't push the pedal down more than half way...I could TAC it out, but as soon as I got on it, it would POP,POP,POP!
by the way...I have a 1996 LS with a JDM GSR swap...not that it really matters in this situation...
So, I decided to pull the car in and do some TLC to my car that was much overdue.....
~New Head gasket
~New Cap (whole distributer is less than a year old...cap was cracked...rotor was still in good shape)
~New Throttle Body Gasket
~New Intake Manifold Gasket
~New Spark Plug Seals In Valve Cover
~New NGK Irridium Spark Plugs
~New Omni TPS Sensor
~New Fuel Filter (thought that might be why it was backfiring....it was extremely clogged/dirty, but it did not stop the back firing)
~Reset The Timing
Now, after all of that, it still does it and here is a key point....it only does it when it gets warm. I can floor it when it's cold and it will not putter at all! PLEASE HELP ME GUYS!!!
Old Nov 9, 2007 | 11:37 PM
honda1982's Avatar
Back-Fire is mostly due to Ignition Failure. So it can be anything from Spark-plug to Dizzy.
This happen to me before when I drove on the HwY and the car back-fire like crazy under full-throttle but partial thottle it was OK.
Check you IGNITER & Ignition Coil. I replace both and it didn't back fire anymore.
Old Nov 9, 2007 | 11:38 PM
ez12a's Avatar
maybe your belt skipped a few teeth?
Old Nov 9, 2007 | 11:40 PM
JaayDeeM's Avatar
Default Re: (honda1982)
Yea...I was thinking that, but I just replaced the coil less than a year ago when it completely failed on me in the middle of a busy intersection! lol I will leave that as a last resort...but if it is then I will probably go with MSD.
Old Nov 9, 2007 | 11:41 PM
JaayDeeM's Avatar
Default Re: (JaayDeeM)
I checked my belt...that can't be it, because it would be doing it all the time....wouldn't it? I figure if it were timing, it would be constant....???
Old Nov 9, 2007 | 11:45 PM
honda1982's Avatar
So the Coil is new but the Igniter is Old??? I've this problem 2years ago and couldn't figure it out why my car keep Back-fires for 2week. I change everything Spark-plug,cap&rotor,Spark-Wires. But it still backfire, until I brough the igniter & coil that it stop backfiring. I got the igniter &coil on ebay $100 for both.
Old Nov 9, 2007 | 11:46 PM
honda1982's Avatar
Borrow someone Dizzy and test it out for a day. I think you will find out if it is the cause or not.
Old Nov 10, 2007 | 04:54 PM
JaayDeeM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda1982 &raquo;</TD></TR><TR><TD CLASS="quote">So the Coil is new but the Igniter is Old??? I've this problem 2years ago and couldn't figure it out why my car keep Back-fires for 2week. I change everything Spark-plug,cap&rotor,Spark-Wires. But it still backfire, until I brough the igniter & coil that it stop backfiring. I got the igniter &coil on ebay $100 for both.</TD></TR></TABLE>
I will try that out.....when you buy the whole dizzy....it only comes with a new coil, rotor, and cap??? If that's the case, then the Ignitor is the original JDM!!! lol I had someone install the dizzy for me awhile back and it ran great until now....I will look into the ignitor...thanks
JDM_SOHC
Jun 29, 2011 11:10 PM
Kahuna
Sep 10, 2010 09:52 AM
DrakeMK3
Southeast (Sales)
11
Sep 7, 2006 01:37 PM
DrakeMK3
May 7, 2006 05:17 AM
DrakeMK3
Southeast (Sales)
May 7, 2006 05:16 AM
