Got a problem with my idle!
Old Nov 11, 2007 | 10:53 AM
OneCrzySetup's Avatar
Default Got a problem with my idle!
Hey guys whats going on? i got a question, i just finished my ls/vtec turbo build in my 94 teg. now when i first started the motor it idled very weird. like it was bouncing back and forth between 2k-3k.. so i replaced the I.A.C. this morning and the car didn't do it as bad, but still did it. but once it warmed up the car idled fine. If its still doing it after i replaced the I.A.C. what else can it be?
Old Nov 11, 2007 | 11:18 AM
94gsrIntegra's Avatar
Default Re: Got a problem with my idle! (OneCrzySetup)
may be the fast idle valve?
Old Nov 11, 2007 | 05:16 PM
matsgsr's Avatar
there is some play in the throttle body. if it is open even slightly, you may see high rpm's at idle. Also, after your tune, the fuel map might be running a little rich at idle.
Old Nov 11, 2007 | 05:45 PM
rdeezy78's Avatar
Default Re: Got a problem with my idle! (94gsrIntegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94gsrIntegra &raquo;</TD></TR><TR><TD CLASS="quote">may be the fast idle valve?</TD></TR></TABLE>
x2
check that out.
Old Nov 11, 2007 | 05:52 PM
PACT man's Avatar
Default Re: Got a problem with my idle! (rdeezy78)
Could be a vacuum leak.
Old Nov 11, 2007 | 06:10 PM
D@9 A.D.B.'s Avatar
Default Re: Got a problem with my idle! (PACT man)
ALL of these could be the culprits....was it professionally tuned also?
Old Nov 12, 2007 | 05:17 PM
Default Re: Got a problem with my idle! (D@9 A.D.B.)
not yet im going to get tuned next tuesday.
Zee.I
Jul 11, 2021 11:36 PM
LukieLuc
Sep 19, 2007 07:37 PM
kihun_cha
25
Aug 5, 2004 09:49 PM
ILOVEGIRLS
Mar 31, 2004 12:58 PM
TurboCRVTEC
Oct 9, 2002 05:38 AM
