b20vtec help..
Old Dec 18, 2007 | 06:25 PM
lsvtec2000's Avatar
Default b20vtec help..
im about to build my b20 vtec this week and ive been reading alot about clearance issues..and also about how much power this setup makes..im goin to be running a stock b20b block..stock pistons,arp rod bolts..or course vtec oil and water pumps..ls crank and ls rods..b16 head..pretty much fully worked..full port and polish,skunk 2 springs and retainers..itr headers..evo2 exhaust..comptech box intake..b16 tranny..stage 2 clutch..im plan on using skunk 2 stage 2 cams..so my question is will have clearance issues with these cams..if so what should i do..and about how much power will this setup make..please help..
Old Dec 18, 2007 | 06:26 PM
Micha's Avatar
FAILWGN
Default Re: b20vtec help.. (lsvtec2000)
You won't have enough compression for those cams.
Old Dec 18, 2007 | 07:05 PM
MilanoRedDC2's Avatar
Clearance issues as far as valve to piston contact?
Old Dec 18, 2007 | 07:22 PM
lsvtec2000's Avatar
Default Re: b20vtec help.. (MilanoRedDC2)
yea..valve clearance
Old Dec 18, 2007 | 07:24 PM
Micha's Avatar
FAILWGN
Default Re: b20vtec help.. (micha)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by micha &raquo;</TD></TR><TR><TD CLASS="quote">You won't have enough compression for those cams. </TD></TR></TABLE>
Old Dec 18, 2007 | 07:54 PM
lsvtec2000's Avatar
wut compression should i be running fro these cams and will i have an issue with valve to piston clearance
Old Dec 19, 2007 | 09:57 PM
Efk9HYBRID's Avatar
i have a b20 vtec set up with gsr head n skunk 2 manifold and try y header but if u have any questions or concers about a set up like that u should hit up Andre from powerspeedmotorsports.com they have help me built the perfect b20vtec set up.
Old Dec 20, 2007 | 03:57 AM
lsvtec2000's Avatar
Default Re: b20vtec help.. (Efk9HYBRID)
ok thanks..wut setup are u runnnin
CivSiClone_96
26
Oct 9, 2008 02:54 PM
B20 Civic
Jan 29, 2008 05:58 AM
B20 Civic
Jan 18, 2008 06:09 AM
Hatchorama
Aug 28, 2006 12:34 PM
c5_el
12
Apr 3, 2006 08:20 AM
