Weird idle problem?
Old Dec 23, 2007 | 10:18 AM
BoltonGSR's Avatar
Default Weird idle problem?
I have a B20 in my 97 integra.. LS computer and bolt on mods... Its basically an ls integra...
Its been running fine for months but recently it has been idling irratically... it goes from 1000 rpm to 1500 rpm when im at a stop and it spits no codes???
I cant seem to find a vaccuum leak either, any thoughts?
Old Dec 23, 2007 | 11:31 AM
97' Integra's Avatar
Do you know if the cams and timing belt are timed right? Have you checked your fuel filter? Spark plugs? iono what could cause it
Old Dec 23, 2007 | 06:51 PM
BoltonGSR's Avatar
Default Re: (97' Integra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97’ Integra &raquo;</TD></TR><TR><TD CLASS="quote">Do you know if the cams and timing belt are timed right? Have you checked your fuel filter? Spark plugs? iono what could cause it</TD></TR></TABLE>I dont think its any of those..
Any other suggestions, i cant figure it out...
Old Dec 23, 2007 | 07:28 PM
weavertime1's Avatar
Default Re: (BoltonGSR)
IACV...Idle Air Control Valve...Sometimes the plunger within this device, located on the back top part of your intake manifold, will get stuck causing the car to idle erratically. It is possible to take this valve off and clean it with air intake cleaner/ carb cleaner, etc. If you search on H-T you will find quite a few posts explaining this procedure. Good luck!
Old Dec 24, 2007 | 02:26 AM
egb18c5's Avatar
Default Re: (weavertime1)
honda IAC sucks
Old Dec 24, 2007 | 05:18 AM
jlfrnce's Avatar
Default Re: (egb18c5)
could also be a IM gasket leak spray it down at anywhere there is a gasket with some carb cleaner
Old Dec 24, 2007 | 06:33 AM
BoltonGSR's Avatar
Default Re: (jlfrnce)
Thanks for those tips... ill look into those. Although i dont think it would be the intake mani gasket... its brand new.
Old Dec 24, 2007 | 09:21 AM
IHTFP's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by weavertime1 &raquo;</TD></TR><TR><TD CLASS="quote">IACV...Idle Air Control Valve...Sometimes the plunger within this device, located on the back top part of your intake manifold, will get stuck causing the car to idle erratically. It is possible to take this valve off and clean it with air intake cleaner/ carb cleaner, etc. If you search on H-T you will find quite a few posts explaining this procedure. Good luck! </TD></TR></TABLE>
search for the Fast Idle Thermal Valve (FITV) too. that might be causing a problem
Old Dec 24, 2007 | 01:26 PM
BoltonGSR's Avatar
Default Re: (IHTFP)
Actually...
Exactly right...
I unscrewed it, sprayed it down with carb cleaner and damn.. the screen was diirrrrty as hell!!
I wiped off the screen and let the carb cleaner drain out.. and that was it... idle problem was fixed
Thanks
and
To the knowledge of this site
Old Dec 24, 2007 | 06:19 PM
No problem man! Good luck with your teg.
seldon
Jul 1, 2008 06:51 PM
tomegun123
Aug 10, 2005 06:16 AM
mrusel
Feb 25, 2004 12:08 AM
myhatchrips
Apr 13, 2003 02:51 PM
FuzzyGreen
Apr 13, 2002 06:08 PM
